Kitapları tarayıp bilgisayar ortamına aktarmada en çok uğraştıran kısım sayfaları çevirmek bu iş için profosyonel cihazlar üretiliyor ayrıca DIY aleminde bir çok çalışma var yazar otomatik kitap tarayıcı robotun mekanik kısımlarını Lego kit ile yapmış zaten en çok uğraştıran mekanik sonrasında tarayıcı hızına göre motor kontol devresi yapmak kalıyor
Otomatik Kitap Tarayıcı Robotun LeoCad ile hazırlanmış kaynak çizimleri var motor kontrol içinde Motor Sürücü Devreleri Cnc Kontrol kategorisinden uygun bir devre seçebilirsiniz
How to Make a Full Auto Book Scanner
After the invention of hyperpaper, I began to scan my books. Soon I found out that what I expected was true — It was awesomely BOREING!
If this drudgery were to be automated!
Scanning a book involves picking up the book from the scanner carefully so that you won’t change the current pages, and turning pages precisely. These activities are as easy as breakfast for human beings. However, our sophisticated biomachienery owe a lot to the Evolution. Without its support, the activities are far too difficult for robots.
Once started, the machine opens the each page of the book and scans the content. The whole process is automatic.
The lesson of this story is that LEGO is great.
How it works
The Glider is wound up, The Shuttle is at the right position.
The Shuttle moves to the left.
The Glider winds down until it touches the book.
The Shuttles moves to the right. The Glider, touching the book, filps the page.
The Glider winds up.
The Balance is lift up. The computer detects the event and sends message to the scanner.
The machiene pauses for 35 seconds, while the scannaer is working.
The Balance lifts down.
Repeat.
Yayım tarihi: 2012/09/08 Etiketler: lego robot, otomatik kitap tarayıcı
