Kicad 3D Kütüphane Arşivi
| Haziran 14, 2023 Tarihinde güncellendi
Bildiğim kadarı ile Kicad en gelişmiş bedava pcb, şema çizim programı ve çok gelişmiş detaylı bir program profosyonel, ticari işler bile Kicad ile yapılabilir. Kicad kullanıcılarının işine yarayacak kicad 3d mikrodenetleyici, kicad 3d soketler, 3d pasif komponentler, kicad lcd eranlar, led display vb. bir çok malzemenin 3d kütüphane dosyaları…
kicad-library-3d-dip-switchs-piano kicad-library-coolers kicad-library-relays kicad-library-transistor-ic-3d
kicad-library-3d
Kicad Area Libraries of components for layout, PCB footprints and 3D modules developed by me and collaborations, participate! (Note: the items below that do not have 3D footprint (module), or component to the scheme, they are already available – even if the names do not indicate, directly, the same often holds true in the opposite direction – component without footprint and/or 3D already have an equivalent, see the topic tips!) (thank´s to Andy Collison for initial translation).
Added : 01/09/2005 Updated: 24/08/2008
Description Author
Kicad PIC Microcontrollers Renie S. Marquet
Kicad LCD graphic display 128×64 G128641B Renie S. Marquet
Kicad 3×4 Keypad Renie S. Marquet
Kicad Sockets for CI 8 to 40 pins of various widths (see tips) Renie S. Marquet
Kicad ZIF Socket 40 pin Renie S. Marquet
Kicad 92 Resistors all Colour Coded Renie S. Marquet
Kicad Electrolytic capacitors “more realistic looking” (see tips) Renie S. Marquet
Kicad Green, yellow and white/blue LED 5mm and 3mm Renie S. Marquet
Kicad SMD Components (SOIC24, SOIC28, Tssoic24 and Tssoic28) Renie S. Marquet
Kicad Test socket 1 to 12 ,14, 16, 18 and 20 pins Renie S. Marquet
Kicad Bridge rectifier (+ layout for schematic) Renie S. Marquet
Kicad Male CN2 connector Renie S. Marquet
Kicad ISA bus connector 62 pins Renie S. Marquet
Kicad Crystal Oscillators (square, rectangular, low profile 3-pin Renie S. Marquet
Kicad AD TCL5540 Texas (R) Renie S. Marquet
Kicad TO220 vertical case Renie S. Marquet
Kicad Molex connector (single and double)
10×1, 10×2, 20×1 e 20×2
Renie S. Marquet
Kicad Trimpot multiturn Renie S. Marquet
Kicad Digital Potentiometers Dual Michochip (R), MCP2xxxx Renie S. Marquet
Kicad Push Button Switch 4 Pin Version Renie S. Marquet
Added on : 01/02/2006 Updated 01/02/2006
Description Author
Kicad o_analog, migrated from Orcad; aprox. 70 comp.Carlos Dilger
Kicad o_assembly, migrated from Orcad; aprox. 45 comp.Carlos Dilger
Kicad .o_cmos, migrated from Orcad; aprox. 150 compCarlos Dilger
.o_device, migrated from Orcad; aprox.190 comp.Carlos Dilger
.o_ecl, migrated from Orcad, aprox 110 comp.Carlos Dilger
o_intel, migrated from Orcad, aprox. 75 comp.Carlos Dilger
o_ladder, migrated from Orcad, aprox. 35 comp.Carlos Dilger
o_memory,migrated from Orcad, aprox.105 comp.Carlos Dilger
o_moto, migrated from Orcad, aprox 50 comp.Carlos Dilger
o_national, migrated from Orcad, aprox. 10 comp.Carlos Dilger
o_rf, migrated from Orcad, aprox. 40 comp.Carlos Dilger
o_school, migrated from Orcad, 7 comp.Carlos Dilger
o_shapes, migrated from Orcad, aprox. 30 comp.Carlos Dilger
o_tilsi, migrated from Orcad, aprox. 60 comp.Carlos Dilger
o_ttl, migrated from Orcad, aprox. 410 comp.Carlos Dilger
o_user, migrated from Orcad,aprox. 150 comp.Carlos Dilger
o_zilog, migrated from Orcad, aprox. 10 comp.Carlos Dilger
MSP430F1201,MSPP430F1232,MSP430F169.Bruno Milhoci
Added : 06/06/2006 Updated: 06/06/2006
Description Author
Kicad Connectors RJ45-AMP, RJ45-TFN1-64P, RJ45-TFN1-88P, RJ45-TFN3-108P.Renie S.Marquet
Kicad Connectors Mini-din 6 pins (PS2), Mini-din 3 pins, Mini_din 4 pins., Mini_din 5 pins, Mini_din 7 pins, Mini_din 8 pinsRenie S.Marquet.
IFT’s including core and screening canRenie S.Marquet.
Added : 01/07/2006 Updated: 24/08/2008
Description Author
Kicad TransformersRenie S.Marquet.
Kicad Fuses and fuseholdersRenie S.Marquet.
Kicad Led Displays 7 segement red and green, single and double bar green and red LEDsRenie S.Marquet.
Kicad Horizontal Coils with and without ferrite coreRenie S.Marquet.
Kicad Heatsinks for TO220 case styleRenie S.Marquet.
RJ12 and USB socketsRenie S.Marquet.
Added : 03/07/2006 Updated 24/08/2008
Description Author
Dipswitches 4 , 8, 10 and 12 wayRenie S.Marquet.
Added : 23/07/2006 Updated 23/07/2006
Description Author
Kicad ZIF sockets 32, 28, 24 and 20 pins greenRenie S.Marquet.
ZIF sockets 32, 28 and 24 pins blueRenie S.Marquet.
SPDT mini switches and slideswitches.
3, 10 , 12 way DIPswitch
Renie S.Marquet.
RCA phono socket in 3 types and 3 colours each typeRenie S.Marquet.
New Bornier connector screw
terminals 2 to 6 way
Renie S.Marquet.
Jumpers strip, 2 pins in blue, red, yellow & grey.Renie S.Marquet.
2 battery holders for PCI motherboards and
CR2032 battery.
Renie S.Marquet.
Mini Push button switches (long and short shaft) for PCB mounting.Renie S.Marquet.
Horizontal and Vertical TrimmersRenie S.Marquet.
DB37 connector (Male and Female)Renie S.Marquet.
Kicad PLCC IC’s 28, 44, 52, 68 and 84 pinRenie S.Marquet.
Kicad PLCC sockets 28, 44, 52, 68 and 84 pinRenie S.Marquet.
Kicad Molex connector up to 28 pinsRenie S.Marquet.
Kicad Dual USB Connector (footprint USB single and double)Renie S.Marquet.
Added : 14/08/2006 Updated 14/08/2006
Description Author
Kicad IDC Connectors non-lockingRenie S.Marquet.
IDC Connectors lockingRenie S.Marquet.
IDC Connectors locking 90 degreesRenie S.Marquet.
Added : 03/09/2006 Updated 03/09/2006
Description Author
4 new mini push button switchesRenie S.Marquet.
Kicad Potentiometers, small and large rotary and slidingRenie S.Marquet.
Kicad Rotary encoders, BCD and HexRenie S.Marquet.
Kicad 3 relay modelsRenie S.Marquet.
LCD display 16 characters 2 lines
LCD display 16 characters 4 lines
Renie S.Marquet.
Object to place in the 3D card in 4 different colors (see video tutorial on the topic Books)Renie S.Marquet.
Added : 24/09/2006 Updated 24/09/2006
Description Author
Kicad Heatsink and hardware for TO3 case and general purpose heatsinkRenie S.Marquet.
2 fan multi-use (change scale) can be used together
with heat sink
Renie S.Marquet.
Kicad Mounting Hardware. 4 types of bolts, threaded bar and nut (for use as a spacer).Renie S.Marquet.
Kicad PCB supportRenie S.Marquet.
Pin_array with locking 2 to 20 pinsRenie S.Marquet.
Pin_arrays with locking pins 2 to 20 pins 90 degreesRenie S.Marquet.
Added : 04/10/2006 Updated 04/10/2006
Description Author
Modules PC/104 8-bit and 16-bitRenie S.Marquet.
Added : 27/05/2007 Updated 27/05/2007
Description Author
Kicad USB “B” type connectorRenie S.Marquet.
90 degrees pin array connector, 1 to 20 pinsRenie S.Marquet.
Kicad Dual 90 degrees pin array connector 1 to 20 pinsRenie S.Marquet.
Kicad Smart Card Connectors for 8 and 16 pinsRenie S.Marquet.
Piezo soundersRenie S.Marquet.
Added : 08/07/2007 Updated 24/08/2008
Description Author
Kicad Female Connectors to PCB, 1 to 20 pinsRenie S.Marquet.
7 new key switchesRenie S.Marquet.
Rotary switches 1×12, 2×6, 3×4, 4×3 etc.Renie S.Marquet.
7 types of 3.5mm jack socketRenie S.Marquet.
Added : 22/09/2007 Updated 22/09/2007
Description Author
Kicad 4 control knobs different coloursRenie S.Marquet.
Kicad Connectors for SD and MD cardsRenie S.Marquet.
Connector for Compact FlashRenie S.Marquet.
9 optocouplersRenie S.Marquet.
Added : 10/12/2007 Updated 10/12/2007
Description Author
210 libraries of modules (footprints) migrated from EagleRenie S.Marquet.
5 RJ45 multi-modulesRenie S.Marquet
8 RJ45 multi-modulesRenie S.Marquet
Kicad 4 Metal trimmersRenie S.Marquet
7 Multi turn (Cermet) TrimmersRenie S.Marquet
4 Round TrimmersRenie S.Marquet
Kicad8 Square plastic trimmersRenie S.Marquet
Various trimmersRenie S.Marquet
Added : 08/06/2008 Updated 08/06/2008
Description Author
Kicad 522 libraries of components for schematic editor migrated EagleRenie S.Marquet
Added : 20/06/2008 Updated 21/06/2008
Description Author
Kicad 8 pressure sensor MPX2050 line (scale 1.5, 1.5, 1.5)Renie S.Marquet
10 pressure sensor MPX5700 line (scale 1.5, 1.5, 1.5)Renie S.Marquet
Kicad PC power connectors from 2 to 24 pins (scale 2,2,2)Renie S.Marquet
Added : 21/06/2008 Updated 21/06/2008
Description Author
Barometric sensor MS5540BRenie S.Marquet
Kicad Humidity and temperature sensors SHTxx seriesRenie S.Marquet
Added : 23/06/2008 Updated 23/06/2008
Description Author
Kicad Connector AmpSeal32Renie S.Marquet
3 types of mini fuse holderRenie S.Marquet
Added : 09/08/2008 Updated 09/08/2008
Description Author
Kicad DSPIC30F4013David Ribeiro
Kicad Buck Regulator LM2575David Ribeiro
Kicad I2C Port Expander MCP230xxDavid Ribeiro
Kicad Temperature gauge with I2C bus TC74David Ribeiro
EM202 Ethernet ControllerDavid Ribeiro
Power Resistors Series KPRenie S.Marquet
Power Resistors Series MRenie S.Marquet
Power Resistors Series KWPRenie S.Marquet
Power Resistors Series KHRenie S.Marquet
Kicad Power Resistors Series HSRenie S.Marquet
Nixie Tubes 0 to 9Renie S.Marquet
Added : 01/11/2008 Updated 01/11/2008
Description Author
Kicad 24 Pin array connector refurbishedRenie S.Marquet
24 Pin array connector refurbished 90 degreesRenie S.Marquet
24 Dual pin array connector refurbishedRenie S.Marquet
24 Dual Pin array connector refurbished 90 degreesRenie S.Marquet
MOSFET dual N channelRenie S.Marquet
SOT 103Renie S.Marquet
LMD18254 – Driver stepper motorRenie S.Marquet
Relay model sh MetaltexRenie S.Marquet
Micro switch used in mousesRenie S.Marquet
Jack Lumberg 1503-09Renie S.Marquet
Kicad TO92 pinout horizontal and verticalRenie S.Marquet
Kicad Objects for plates, 4 colour semi-transparentRenie S.Marquet
Dip switches 2 to 10 way and 12 way piano type in blue and redRenie S.Marquet
30 styles of TOxxx case outlinesRenie S.Marquet
Added on : 12/04/2009 Updated 12/04/2009
Description Author
Kicad 12 Electrolytic capacitors refurbished light blueRenie S.Marquet
12 Electrolytic capacitors refurbished orangeRenie S.Marquet
12 Electrolytic capacitors remodeled dark blueRenie S.Marquet
Kicad 96 colour coded resistors (horizontal)Renie S.Marquet
96 colour coded resistors (vertical)Renie S.Marquet
Added : 01/05/2009 Updated 01/05/2009
Description Author
3 Connectors RJ45 EthernetRenie S.Marquet
6 connectors min DIN 3 to 8 pinRenie S.Marquet
Kicad 14 LEDs remodeled in 7 colors, 5mm and 3mmRenie S.Marquet
Added : 06/06/2010 Updated 06/06/2010
Description Author
Kicad Discret CIs (10 symbols)Bernd Wiebus
Varius symbols (223 symbols)Bernd Wiebus
Transformers (2 symbols)Bernd Wiebus
Clips and batterys AA, AAA e 9VRenie S.Marquet
12 Minifit conectors 90 degrees 2 to 24 pins (scales 2 , 2 , 2)Renie S.Marquet
Pressure sensors MPXH6400A and MPXH6440A (scales 0.5 , 0.5 0.5)Renie S.Marquet
Kaynak: reniemarquet.cjb.net/bibliotecas_en.html
kicad-3d-kutuphane-arsivi-dw-link
Yayım tarihi: 2012/07/22 Etiketler: , ,
3 Yorum “Kicad 3D Kütüphane Arşivi
  1. seronseron
    Gevv,
    Bunu güncelleyebilir misin? 2018 tarihli başlıklar gördüm kaynak sitede.
    Bir de bi durum var. Ben bunu programa nasıl ekleyeceğimi anlayamadım. Yardımcı olur musun?
