“ST Lighting Designer Design your Electronic Ballast for Fluorescent Tubes and CFLs” balast tasarım programı oldukca şık ve gelişmiş PFC, dimmer vb. bir çok özellik var ayrıca “Inductor desing” aracı farklı uygulamalar içinde kullanabilir.
Balast tasarım programının çalışması için bilgisayarınızda Microsoft .NET Framework version 2.0 ya da daha üst versiyonu yüklü olmalı
Several solutions are implemented: the user has just to specify the desired high-level requirements to obtain a full set of information to realize his own e-ballast!
Just three steps:
Specify the high-level requirements: mains range: European, American or Wide, lamp & ignition type, additional design options: PFC, dimming Select and Execute the preferred Solution: fixed or variable frequency based on our IC L6585, L6574, L6569, L6562 discrete solution based on STx724, STx83003, STx93003.
Get your Design and refine it to better meet your needs:
bill of materials,
fully annotated schematic,
lamp circuit working point, steady state simulation,
involved devices datasheet, application notes,
Örnek balast tasarım videosu;
Balast tasarım program ST Lighting Designer 1.1.6 – Setup;
Yayım tarihi: 2011/05/11 Etiketler: Ballast Designer, cfl balast, electronic ballast circuit, elektronik balast devresi
