A volume setting passive integrated possible by the high output level of modern sources, and a structure of the amplifier gain sufficient floors limited to essential guarantee the transparency of the system. Yield loudspeakers and damping for ‘pregnant will be the selection criteria.
A Release to push-pull “common drain”: his first schemes have 20dB of reaction against the level of DHT + noise is less than 0.05%, bandwidth than 200kHz. Le gain est de 29dB (x28). The gain is 29dB (x28). Very goods for pregnant crossover agreement and bass reflex. The damping more than 100 are pure generating tension.
Kaynak: jm.plantefeve.pagesperso-orange.fr/sche.html
Yayım tarihi: 2008/08/27 Etiketler: amplifikatör devreleri, Class AB, mosfet, transistörlü anfi devreleri
bu anfi kaç paraya mal olur bilgi veriri misiniz?
