Op-Amp Tester Circuit
| June 21, 2014 Updated
With a simple op amp integrated circuit can test. In general, a very op amp integrated circuit `s leg connections are the same red LED to indicate that the firm used the op amp LED lights will give a solid
seems a channel 8 in the circuit diagram of a multi-legged opamp is binary except for the feed section of the circuit to be completed two as in bore phenolic board photos
In many of the op amp supply voltage for the circuit 9 volt supply is symmetrically divided voltage obtained artificial symmetric. integrated TLE2426 used for this job
Op-Amp Tester Schematic
op-amp-test-devresinin-semasi
Source: tangentsoft.net/elec/opamp-tester.html
Published: 2010/03/07 Tags:
1 Comment “Op-Amp Tester Circuit
    CNC Drilling Machine Control Dirve Board Atmel AT89C2051 L297 L298
    Printed circuit board drilling machine on the Atmel AT89C2051 microcontroller L297 L298 motor drivers.. software does not open hex ​​code provided free computer control program, but other parts of the circuit (motor drives, serial communications, etc..) Print circuit drawing can be useful.
    CNC Drilling Machine Project
