Ironing Board with pcb or laminator while pressing a lot of paper to be used with pcb type there Avinash, label, handmade paper, etc. I’m experimenting with the latest label paper, and I have no need to use other paper continue but continues to have different methods.
The author used the aluminum foil for the pressure of the pcb before tinfoil on the edges of the foil blanks in A4 paper taking meandering steadies
Laser printer paper after placing on the aluminum foil and cut the foil pcb pcb output takes places on a plaque
then put a thin towel over the foil onto the pcb yapışıncaya pcb pressure so if you note here ironing irons blister-shaped until done
Finally, a good part of the business PCBs plaque acid thrown in aluminum foil with acid so that only the toner is completely unraveling pcb parts printed output is not ethylene foil, etc. now. Not only does the cleaning say cleaning up toner
Source: alex-avr2.livejournal.com/9250.html
Published: 2012/08/17 Tags: interesting projects electronics
Multi function RC5 Remote RGB Led Control Circuit PIC16F737
PIC16F737 RGB led control circuit based on microcontroller for remote control (RC5 Protocol) can work with different modes according to the color of the color change of the environment with the photo sensor a905013. Quick, easy color change control over specifying a single color, etc. The author used the pic output 12v 5 mm led Ribbon le PWM method of traversing circuit with MOSFETs BUZ71 12v 3 amps (150 led to 3a) adapter with the executable.
