Devre jfet girişli tl084 opamp üzerine kurulu frekans seçimi ister komutatör ile kademeli ister potans ile yapılabilir
Sinyal : sinüs, kare
Çıkış frekansı : 10 Hz den 100 kHz ayarlanabilir kademeli
Frekans kademe : 10Hz 100Hz 1kHz 10kHz 1kHz
AF çıkış düzeyi : 0 6Vss
Çıkış Empedansı : 1 K
THD toplam harmonik gürültü : 0.02% (1 kHz, 400 Hz)
Sinyal seçimi : DC ve AC
DC ofset ± 2 V ayarlanabilir
Besleme gerilimi : 12V AC adaptör yada 9V pil
Designed for use in hobby projects delivers the signal generator SG 1000 very clean sine waves with a THD of <0.02% and square waveforms with adjustable Pulse / pause ratio. The frequency of the SG 1000 is between 10 Hz and 100 kHz.Signal and tone generators for Testing and adjustments of audio and Measuring instruments especially important tools and belong to the basic equipment of a Hobby laboratories. With respect to the waveform are often high demands on put a sine wave generator, with the not easy to function generators be fulfilled.
Kaynak: http://www.elv-downloads.de/service/manuals_hw/28027_SG1000_km_web.pdf
Yayım tarihi: 2009/06/03 Etiketler: 10hz 100khz generatör, analog sinyal generatörü, sinyal üretici devre, TL084
