Çok ilginç bir robot projesi pencelerelerdeki sineklikleri temizleme içintasarlanmış temizlikci robot sistemin beyni atmel at90ls8535 mikro denetleyicisi kaynak c yazılımı verilmiş.
Robot projesinin uygulayamasanızda devre bölümleri kaynak yazılım işinize yarayabilir özellikle motor sürücü bölümü h-bridge köprü bağlantılı mosfetli sürücü katı bulunuyor
mrfisc.c yazılımı
/********************************************* Project : MrFisc Version : 1.0 Date : 9/12/2003 Author : Andrew Oudyn Comments: Firmware for the Mr Fisc Micro Robotic Fly & Insect Screen Cleaner Chip type : AT90LS8535 Clock frequency : 4.000000 MHz Memory model : Small External SRAM size : 0 Data Stack size : 128 *********************************************/ // include files for this project #include <90S8535.h> //contains register information for the processor #include <stdio.h> // Standard Input/Output functions #include <delay.h> //Delay functions #include <math.h> //Maths library #include <stdlib.h> //for ftoa #include "mrfisc.h" //Set and read individual bits Macro #define setBit(port, bitP, value) if (value == 1) { port = port | (1<<(bitP)); } else { port = port & ~(1<<(bitP)); } #define getBit(port,bitP) ((port & (1<<(bitP)))>>(bitP)) // Read the AD conversion result unsigned int read_adc(unsigned char adc_input) { ADMUX=adc_input; // Start the AD conversion ADCSR|=0x40; // Wait for the AD conversion to complete while ((ADCSR & 0x10) == 0); ADCSR|=0x10; return ADCW; } void check_status(void); void motor(unsigned char action); void wait(void); void initialise(void); void correct(void); // Global Variables float angle = 0; //the angle of Mr. FISC float vBat = 0; // Battery Status in Volts signed int heading = 0; //the nearest integer value for the heading in degrees unsigned char direction = HEAD_RIGHT; //always start at the top left so always go right unsigned char whichway; void main(void) { unsigned char start = 1; //To signify program initialisation initialise(); DDRC = SetPortC; //0011 0000 set the port C to external input. whichway = STOPPED; wait(); while (1) { if(PINC.RIGHT_SENSOR == 1) { heading = 0; start = 0; } else if(PINC.LEFT_SENSOR == 1) { heading = 0; } else if(PINC.FRONT_SENSOR == 1) { motor(STOP); direction = HEAD_LEFT; if(start == 0) { motor(STOP); wait(); start = 1; } heading = TRAJECTORY; // heading in degrees } else if(PINC.BACK_SENSOR == 1) { motor(STOP); direction = HEAD_RIGHT; if(start == 0) { motor(STOP); wait(); start = 1; } heading = -TRAJECTORY; // heading in degrees } correct(); } } /* check_status() is used to read all of the ADC values going into the micro. These include the battery voltage, the X and Y tilt values from the accelerometer. Port A is also used as a digital IO port and aswell as taking the anologue tilt readings, a digital version can also be obtained by pooling the two digital input pins, 4 and 5 and using a timer counter. Port A also control the Serial IC and the Charge pump. */ void check_status() { float xTilt = 0; // Value of tilt in X direction float yTilt = 0; // Value of tilt in Y direction float xTiltDigi = 0; int countT1 = 0; // time in counts for high pulse int countT2 = 0; // time in counts for low pulse char buffer[] = {0,0,0,0,0,0,0,0,0,0}; // buffer to hold number sent to computer //accelerometer sensativity (60mV x Vcc)/g = (198mV / g) // "zero g" will be at Vcc/2 = 1.65 // use full 10 bit ADC total range of 3.3V / 2^10 = 1024 // Voltage step = 3.22mV / bit // Battery Status //tiltValue = (float)(read_adc(V_BAT)); vBat = (float)(read_adc(V_BAT)*VOLTS_PER_BIT); /* ******* ANALOGUE TILT READINGS ******* */ //tiltValue = read_adc(X_TILT); //read the X tilt value xTilt = (float)read_adc(X_TILT)*VOLTS_PER_BIT; //tiltValue = read_adc(Y_TILT); //read the Y tilt value yTilt = (float)read_adc(Y_TILT)*VOLTS_PER_BIT; /* ******* DIGITAL TILT READINGS ******* */ DDRA = SetPortA; // 1100 0000 // Y tilt readings // The actual time taken is irrelevent, it's the duty cycle that is important // so the delay to keep track of actual time is not required, so long as the // loops are the same. while(PINA.X_TILT_DIGI == 1){} while(PINA.X_TILT_DIGI == 0){} //wait for clock to pulse while(PINA.X_TILT_DIGI == 1){ countT1++; } while(PINA.X_TILT_DIGI == 0){ countT2++; } xTiltDigi = ((float)countT1/(countT2 + countT1) - ZERO_G_CYCLE)/CYCLE_2_G; /* ******* CALCULATING AND SENDING ANGLE ******* */ setBit(PORTA, RS232_ON, 1); //turns on the serial IC delay_ms(1); angle = asin(xTiltDigi)*RADS_2_DEGS; //convert to degrees ftoa(angle, 4, buffer); printf("Mr. FISC's DIGITAL Y tilt readings show: %s \r \n", buffer); printf("Heading: %d \r \n", heading); if(whichway == FORWARD) printf("Mr. FISC is going FORWARD \r \n"); else if(whichway == FORWARDLEFT) printf("Mr. FISC is going FORWARD and LEFT \r \n"); else if(whichway == FORWARDRIGHT) printf("Mr. FISC is going FORWARD and RIGHT \r \n"); else if(whichway == BACKWARDS) printf("Mr. FISC is going BACKWARDS \r \n"); else if(whichway == BACKLEFT) printf("Mr. FISC is going BACK and LEFT \r \n"); else if(whichway == BACKRIGHT) printf("Mr. FISC is going BACK and RIGHT \r \n"); else if(whichway == STOPPED) printf("Mr. FISC ain't goin' NOWHERE \r \n"); //ftoa(vBat, 3, buffer); //printf("The battery Voltage is: %s \r \n", buffer); delay_ms(10); setBit(PORTA, RS232_ON, 0); //turns off the serial IC } void correct(void) { check_status(); if(direction == HEAD_RIGHT) { if(heading == 0) { if(angle >= STRAIGHTLINE) { motor(RIGHT_FWD); whichway = FORWARDRIGHT; } else if(angle <= (0 - STRAIGHTLINE)) { motor(LEFT_FWD); whichway = FORWARDLEFT;} else { motor(FWD); whichway = FORWARD; } } else { if(angle >= (heading + STRAIGHTLINE)) { motor(RIGHT_FWD); whichway = FORWARDRIGHT; } else if(angle <= (heading - STRAIGHTLINE)) { motor(LEFT_FWD); whichway = FORWARDLEFT; } else { motor(FWD); whichway = FORWARD; } } } else if(direction == HEAD_LEFT) { if(heading == 0) { if(angle <= (0 - STRAIGHTLINE)) { motor(LEFT_REV); whichway = BACKLEFT; } else if(angle >= (STRAIGHTLINE)) { motor(RIGHT_REV); whichway = BACKRIGHT; } else {motor(REV); whichway = BACKWARDS;} } else { if(angle >= (heading + STRAIGHTLINE)) { motor(RIGHT_REV); whichway = BACKRIGHT; } else if(angle <= (heading - STRAIGHTLINE)) { motor(LEFT_REV); whichway = BACKLEFT; } else { motor(REV); whichway = BACKWARDS; } } } } void motor(unsigned char action) { //flag to determine if Mr FISC is already moving to prevent lots of stop starts if(action == FWD){ PORTB = MOTOR_FWD; } else if(action == REV){ PORTB = MOTOR_REV; } else if(action == LEFT_FWD){ PORTB = MOTOR_LEFT_FWD; } else if(action == RIGHT_FWD){ PORTB = MOTOR_RIGHT_FWD; } else if(action == LEFT_REV){ PORTB = MOTOR_LEFT_REV; } else if(action == RIGHT_REV){ PORTB = MOTOR_RIGHT_REV; } else if(action == STOP){ PORTB = MOTOR_STOP; } } void wait(void) { while(!((PINC.RIGHT_SENSOR == 1)&&(PINC.LEFT_SENSOR == 1))) { PORTD = ALL_RED; //1010 1000 delay_ms(175); PORTD = ALL_GREEN; //0101 0100 delay_ms(175); } PORTD = ALL_OFF; delay_ms(500); PORTD = POWERON; //1100 1100 lights on... } void initialise(void) { // UART initialization Communication Parameters: 8 Data, 1 Stop, No Parity UCR=0x18; // UART Receiver: On UART Transmitter: On UART Baud rate: 9600 UBRR=0x19; ACSR=0x80; // Analog Comparator initialization ADCSR=0x85; // ADC Clock frequency: 125.000 kHz // Port A initialization PORTA = StartPortA; //1000 0000 DDRA = SetPortA; //O,O,I,I, I,I,I,I // Port B initialization PORTB = StartPortB; //0000 0000 DDRB = SetPortB; //I,I,I,I, O,O,O,O // Port C initialization PORTC = StartPortC; //0000 0000 DDRC = SetPortC; //I,I,O,O, I,I,I,I // Port D initialization PORTD = StartPortD; //1111 1100 DDRD = SetPortD; //O,O,O,O, O,O,X,X }
Kaynak: innovexpo.itee.uq.edu.au/2003/exhibits/s363161/
sineklik-temizleme-robotu-atmel-at90ls8535-bocek-robot-dw-link
Yayım tarihi: 2010/02/16 Etiketler: at90ls8535, atmel avr projeleri, atmel devreleri, bocek robot, temizleme robotu
