Popüler olan güç elektroniğinde DCDC ACDC bir çok uygulamada kullanılan eski, yeni smps, pwm kontrol sürücü entegrelerinin proteus isis modelleri ve library dosyaları…
Ayrıca bazı modellerin yanında test için proteus simülasyon devreleride bulunuyor.
Proteus PWM SMPS model listesi;
TL494 PULSE-WIDTH-MODULATION CONTROL CIRCUITS
UC2524 Regulating Pulse Width Modulator
UC3524 Complete PWM Power Control Regulating Pulse Width Modulators
UC2525 Regulating Pulse Width Modulators
UC3526 Regulating Pulse Width Modulator
UC3825 High Speed PWM Controller
UC3842 SMPS Controller
IR2108, IR2109 HALF-BRIDGE DRIVER
IR2153 SELF-OSCILLATING HALF-BRIDGE DRIVER
IR2133 3-PHASE BRIDGE DRIVER
IR2130 3-PHASE BRIDGE DRIVER
IR2125 CURRENT LIMITING SINGLE CHANNEL DRIVER
IR2104 MOSFET IGBT drivers
IR51HD420 high voltage high speed self- oscillating half-bridge
Proteus\4N25\ 4N25.DSN MOT.LIB
Proteus\IR2104 IR2104IC.DSN IR2109IC.DSN IR2104.MDF IR2109.MDF
Proteus\IR21084 IR21084ic.DSN IR21094IC.DSN IR2108.MDF IR21084.MDF IR2109.MDF IR21094.MDF
Proteus\IR2118 IR2118IC.DSN IR2125IC.DSN IR2117.MDF IR2118.MDF IR2125.MDF IR21178.SEC IR2125.SEC
Proteus\IR2130 IR2130IC.DSN IR2130.MDF IR2130IC.SEC
Proteus\IR2130ic IR2130IC.DSN IR2133IC.DSN IR2130.MDF IR2133.MDF IR2130IC.SEC IR2133IC.SEC
Proteus\IR2153 IR2153MT.DSN IR2153D.MDF
Proteus\IR51HD420ICTR IR51HD420ICTR.DSN EX_SAT_2.MDF IR51HD420.MDF IR51HD420.SEC
Proteus\tl494 TL49395.rar TL494!.rar TL494_spice!!!.rar TL494+.rar 494.zip
Proteus\TLP250 TLP250IC.DSN TLP250.MDF VSP.MDF
Proteus\UC252 UC2524IC.DSN UC2524.MDF UC2524.SEC
Proteus\UC252 UC2525IC.DSN UC3526IC.DSN UC2525.MDF UC3526.MDF
Proteus\UC352 UC3526IC.DSN UC3526.MDF UC3526.SEC
Proteus\UC3825 UC3825IC.DSN UC3825.MDF UC3825.SEC
Proteus\UC384 UC3842TEST2.DSN UC38425.IDX DIOD.LIB UC.LIB UC38425.LIB CLR.MDF SRFF.MDF TL493.MDF TL495.MDF TL594.MDF TRAN2P4S.MDF
Proteus\US3842 UC3842TEST2.DSN UC38425.IDX UC.LIB UC38425.LIB SRFF.MDF
Proteus SMPS PWM Entegre Modelleri ca3524 isi proteus, isis sg3524, sg3524 in isis sg3524 isis, proteus tl494 model, sg3524 proteus model
Proteus Kütüphane Ekleme
Proteus programın da yeni proteus library dosyalarını eklemek çok kolay Dosyanın içindeki “.IDX” ve “LIB” uzantılı dosyaları proteus programının kurulu olduğu kılasör içinde ki “LIBRARY” kılasöne kopyalıyorruz.
Not: Bu işlem söncesinde “LIBRARY” kılasörünün bir yedeğini alın her hangi bir sorunda geri yükleme yapabilirisniz. .MDF, .DLL, .SML, .LML gibi dosyalar ise “MODELS” kılasörüne kopyalanır
Proteus v7 kurulu ise:
C:\Program Files\Labcenter Electronics\Proteus 7 Professional\LIBRARY kılasörü içine
Proteus v8 kurulu ise:
C:\Program Files\Labcenter Electronics\Proteus 8 Professional\LIBRARY (32 bit işletim sistemi için)
C:\Program Files (x86)\Labcenter Electronics\Proteus 7 Professional\LIBRARY (64 bit işletim sistemi için)
veya;
C:\Program Files\Labcenter Electronics\Proteus 8 Professional\DATA\LIBRARY (32 bit işletim sistemi için)
C:\Program Files (x86)\Labcenter Electronics\Proteus 7 Professional\DATA\LIBRARY (64 bit işletim sistemi için)
Güncelleme uc384x proteus library dosyaları
Güncelleme: Proteus TL594 IR51HD420 NCP3063 MCP1630 lm2575 IR2153D Proteus IRF serisi mosfetler; IRF7105, IRF7106, IRF7307, IRF7309, IRF7317, IRF7319, IRF7338, IRF7343, IRF7350, IRF7507, IRF7524D1, IRFG6110, IRHG6110, IRHG567110, IRHQ6110, IRHQ567110
Yayım tarihi: 2011/10/03 Etiketler: isis model, isis pwm, isis smps, proteus library, sg3525, sg3525 proteus isis, tl494 proteus isis, uc3842 proteus isis
Bazen her zaman devre kurmak mümkün olmuyor, ilaç gibi geldi bu kütüphaneler..
muchas gracias por los modelos.
desde argentina
SMPS simülasyon iyi de bir de bizim müşterilerin devrelerin performans kontrollerini kim yapar?
simülasyon yapabilen var mı?
smps design yapıyoruz fakat devreyi kurmadan önce simülasyon iyi olur
teşekkür ederim
proteus 8 için kütüphane ekleme nasıl eklerseniz çok memnun oluruz.
Sağol kardeş, çok yararlı oldu.
Merhaba. TLP250 yi proteus kütüphanesine eklemekte sorun yaşıyorum. İçerisinde .lib uzantılı dosya yok .mdf ve .dsn uzantılı dosyalar var. Bunları libraries klasörüne attığımda program arayüzünde göremiyorum. Başka şekilde mi atıyoruz. Yardımlarınızı bekliyorum.
Ustam teşekkürler fakat elemanları nasıl yükleyeceğiz?Yardımcı olursanız teşekkürler
UC3524 içerisinde bu entegre yok yardımcı olabilir misiniz ?
UC2524 ile aynı
UC1524, UC2524, UC3524 hepsi aynı
iw1710 karşılığını araştırdım bulamadım, karşılığını bilen varmı ?
UC2524’ü açıp başka bir devre kurdum çalıştırdım dedim ”can not find model file ”UC2424.MDF” diyor nasıl çözebilirim?
UC2524 ile devre yaptım fakat model tanımlı değil diyor ne yapmam lazım yardım eder misiniz
UC2524.SEC UC2524.MDF dosyalarını C:Program FilesLabcenter ElectronicsProteus xxx ProfessionalMODELS klasörüne kopyalayın
Şimdi gördüm teşekkürler.
Obrigado amigo, me ajudou muito, saudações do Brasil !!!
Thanks from Mexico! It helped me a little bit with a schematic
Merhabalar , UC3842’in mdf uzantılı dosyası rar’ın içinde yok yardımcı olabilir misiniz ? hata alıp duruyorum UC3842.mdf bulunamadı şeklinde
merhaba, yeni dosyalar yazıya eklendi
Merhabalar. Bende hata alıyorum. Tanımıyor diye. Ne yapmam gerekiyor?
Ve güncellenen en son dosyayı indiremedim. Hata alıyorum.
dosya linki güncellendi indirebilirsiniz
DOSYALAR İÇİN TEŞEKKÜR EDERİM . LİB. UZANTILARI YOK BU NEDENLE doğrudan listelere ekleyemiyorum .proteus 7 ve 8 yüklü bende . bunun yerine dosyalardaki örnek devrelerde düzenleme yaparak işlem yapıyorum saygılar
I’m using the new files for the UC3842 but I’m geting the following erros:
cannot open SPICE source file UC.LIB
SUBCKT ‘OP3842’ used in ‘U1_U5’ but not found
Failed to expand subcircuits
Simulation FAILED due to fatal simulator erros.
What can be the problem? Thank you very much.
Hi,
try these lib: uc38-proteus-2.zip
C:\ProgramData\Labcenter Electronics\Proteus 8 Professional\LIBRARY benim pr da burada bulunuyor ..
i want tlp250 library for isis.
Donwnload: proteus-opto-TLP250-4N25-HCPL-3120 pass: 320volt.com
THANKS
Herkese selamlar saygılar. Sayın hocam proteus 8.16 Sp1 programım gayet iyi çalışmasına rağmen labcenter klasörünün içerisinde labriray dosyası maalesef yok. Bu nedenle kütüphaneye yeni parça yükleyemiyorum.
Ayrıca zipli olarak yüklemiş olduğunuz güç entegreleri içinde IDX VE LIB uzantıları yok maalesef. Sadece birkaçında var. Ben mi biryerde hata yapıyorum anlamadım. Lütfen yardımcı olur musunuz. Teşekkürler.
