Devre PIC16C622 mikrodenetleyicisi üzerine kurulu 1Ω 999Ω arası direnç ölçümü 1nF 999 nF arası kapasitör ölçümü yapılabiliryor bilgisayar bağlantısı bulunuyor denetleyici yazılımı assembly ile pc yazılımı Visual Basic ile hazırlanmış. PIC16C622 ve uygulama devresi hakkında tüm detaylar formüller verilmiş orjinal microchip uygulama notudur.
Devre şeması;
The application circuit, called PICMETER, uses a PIC16C622 as a resistance and capacitance meter. The PICMETER uses a variation of the single-slope integrating converter. The linear slope and integrator of Figure 13 are replaced with the exponential charge waveform of an RC. The charge time of a known component is compared against the charge time of an unknown component to determine the value of the unknown component.
A schematic of the PICMETER is shown in Figure 16. All reference designators cited in this section refer to this schematic. Results are transmitted to a PC which displays the value measured.
TITLE "PICMETER Firmware for PIC16C622" LIST P = 16C622, F = INHX8M INCLUDE "C:\PICMASTR\P16CXX.INC" __FUSES _BODEN_OFF&_CP_OFF&_PWDT_ON&_WDT_OFF&_XT_OSC ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- -* ;*- PICMETER - Resistance and Capacitance Meter -* ;*- -* ;*--------------------------------------------------------------------------* ;*- -* ;*- Author: Rodger Richey -* ;*- Applications Engineer -* ;*- Filename: picmeter.asm -* ;*- Revision: 1 May 1995 -* ;*- -* ;*--------------------------------------------------------------------------* ;*- -* ;*- PICMETER is based on a PIC16C622 which has two comparators and a -* ;*- variable voltage reference. Resistance and capacitance is -* ;*- calculated by measuring the time constant of a RC network. The -* ;*- toggle switch selects either resistor or capacitor input. The -* ;*- pushbutton switch starts a measurement. The time constant of the -* ;*- unknown component is compared to that of known component to -* ;*- calculate the value of the unknown component. The following -* ;*- formulas are used: -* ;*- -* ;*- Resistance: Ru = ( Rk * Tu ) / Tk -* ;*- Capacitance: Cu = ( Ck * Tu ) / Tk -* ;*- -* ;*--------------------------------------------------------------------------* ;**************************************************************************** ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- RS232 code borrowed from Application Note AN593 -* ;*- "Serial Port Routines Without Using the RTCC" -* ;*- Author: Stan D'Souza -* ;*--------------------------------------------------------------------------* ;**************************************************************************** xtal equ .4000000 baud equ .9600 fclk equ xtal/4 ;**************************************************************************** ;The value baudconst must be a 8-bit value only baudconst equ ((fclk/baud)/3-2) ;**************************************************************************** ;**************************************************************************** ; Bit Equates ;**************************************************************************** BEGIN equ 0 ;begin a measurement flag DONE equ 7 ;done measuring flag WHICH equ 5 ;R or C measurement flag F_ERROR equ 3 ;error detection flag EMPTY equ 5 ;flag if component is connected V0 equ 0 ;power for R reference ckt V1 equ 1 ;power for C reference ckt V2 equ 2 ;ground for C reference ckt V3 equ 3 ;power for unknown R ckt V4 equ 4 ;ground for unknown C ckt msb_bit equ 7 ;define for bit 7 lsb_bit equ 0 ;define for bit 0 RkHI equ 0x07 ;value of the known resistance, R4, in ohms RkMID equ 0x9D ;measured by a Fluke meter RkLO equ 0x38 CkHI equ 0x07 ;value of the known capacitance, C1, in pF CkMID equ 0x47 ;measured by a Fluke meter CkLO equ 0x48 ;**************************************************************************** ; User Registers ;**************************************************************************** ; Bank 0 W_TEMP equ 0x20 ;Bank 0 temporary storage for W reg STATUS_TEMP equ 0x21 ;temporary storage for STATUS reg Ttemp equ 0x23 ;temporary Time register flags equ 0x24 ;flags register count equ 0x25 ;RS232 register txreg equ 0x26 ;RS232 data register delay equ 0x27 ;RS232 delay register offset equ 0x28 ;table position register msb equ 0x29 ;general delay register lsb equ 0x2A ;general delay register TimeLO equ 0x40 ;Time registers TimeMID equ 0x41 TimeHI equ 0x42 ; Math related registers ACCaHI equ 0x50 ;24-Bit accumulator a ACCaMID equ 0x51 ACCaLO equ 0x52 ACCbHI equ 0x53 ;24-Bit accumulator b ACCbMID equ 0x54 ACCbLO equ 0x55 ACCcHI equ 0x56 ;24-Bit accumulator c ACCcMID equ 0x57 ACCcLO equ 0x58 ACCdHI equ 0x59 ;24-Bit accumulator d ACCdMID equ 0x5A ACCdLO equ 0x5B temp equ 0x5C ;temporary storage ; User Registers Bank 1 ;W_TEMP equ 0xA0 ;Bank 1 temporary storage for W reg ; User defines #define tx PORTB,7 ;define for RS232 TXD output pin ;**************************************************************************** org 0x0 goto init org 0x4 goto ServiceInterrupts org 0x10 init bcf STATUS,RP0 ;select bank 0 clrf PORTA ;clear PORTA and PORTB clrf PORTB bsf tx ;set TXD output pin clrf flags ;clear flags register movlw 0x10 ;load table offset register movwf offset clrf INTCON ;clear interrupt flags and disable interrupts movlw 0x07 ;turn off comparators, mode 111 movwf CMCON call delay20 ;wait for comarators to settle movf CMCON,F bcf PIR1,CMIF bsf STATUS,RP0 ;select bank 1 movlw 0x88 ;WDT prescalar,internal TMR0 increment movwf OPTION_REG clrf TRISA ;PORTA all outputs, discharges RC ckts movlw 0x60 ;PORTA<7,4:0> outputs, PORTA<6:5> inputs movwf TRISB movlw 0x0C ;setup Voltage Reference movwf VRCON bcf STATUS,RP0 ;select bank 0 movlw 0x08 ;enable RBIE interrupt movwf INTCON call vlong ;delay before transmitting boot message call vlong ;to allow computer program to setup call vlong call BootMSG ;transmit boot message bsf INTCON,GIE ;enable global interrupt bit start btfss flags,BEGIN ;wait for a start measurement key press goto start bcf flags,BEGIN ;clear start measurement flag bcf INTCON,GIE ;transmit a start measurement message movlw 'S' ;to the PC call Send bsf INTCON,GIE clrf TimeHI ;reset Time registers clrf TimeMID clrf TimeLO btfss PORTB,WHICH ;detect if resistor or capacitor measure goto Capacitor Resistor bsf STATUS,RP0 ;set V0 to input bsf TRISB,V0 bcf STATUS,RP0 call AnalogOn ;turn analog on clrf TMR0 nop bsf PORTB,V3 ;turn power on to unknown RC ckt RwaitU btfsc flags,F_ERROR ;detect if an error occurs goto ErrorDetect btfss flags,DONE ;measurement completed flag goto RwaitU bcf flags,DONE ;clear measurement completed flag call AnalogOff ;turn analog off call SwapTtoA ;swap Time to accumulator a movlw RkHI ;swap known resistance value movwf ACCbHI ;to accumulator b movlw RkMID movwf ACCbMID movlw RkLO movwf ACCbLO call Mpy24 ;multiply accumulator a and b bsf STATUS,RP0 ;set V3 to input bsf TRISB,V3 bcf STATUS,RP0 call AnalogOn ;turn analog on clrf TMR0 nop bsf PORTB,V0 ;turn power on to known RC ckt RwaitK btfsc flags,F_ERROR ;detect if an error occurs goto ErrorDetect btfss flags,DONE ;measurement completed flag goto RwaitK bcf flags,DONE ;clear measurement completed flag call AnalogOff ;turn analog off call SwapTtoA ;swap Time to accumulator a call Div24 ;divide multiply by known time bcf INTCON,GIE ;disable all interrupts movlw 'R' ;transmit, for R measurement call Send bsf INTCON,GIE ;enable global interrupt bit goto start ;restart Capacitor bsf STATUS,RP0 ;set V2 to input bsf TRISB,V2 bcf STATUS,RP0 call AnalogOn ;turn analog on clrf TMR0 nop bsf PORTB,V1 ;turn power on to unknown RC ckt CwaitU btfsc flags,F_ERROR ;detect if an error occurs goto ErrorDetect btfss flags,DONE ;measurement completed flag goto CwaitU bcf flags,DONE ;clear measurement completed flag call AnalogOff ;turn analog off call SwapTtoA ;swap Time to accumulator a movlw CkHI ;swap known resistance value movwf ACCbHI ;to accumulator b movlw CkMID movwf ACCbMID movlw CkLO movwf ACCbLO call Mpy24 ;multiply accumulator a and b bsf STATUS,RP0 ;set V3 to input bsf TRISB,V4 bcf STATUS,RP0 call AnalogOn ;turn analog on clrf TMR0 nop bsf PORTB,V1 ;turn power on to known RC ckt CwaitK btfsc flags,F_ERROR ;detect if an error occurs goto ErrorDetect btfss flags,DONE ;measurement completed flag goto CwaitK bcf flags,DONE ;clear measurement completed flag call AnalogOff ;turn analog off call SwapTtoA ;swap Time to accumulator a call Div24 ;divide multiply by known time bcf INTCON,GIE ;disable all interrupts movlw 'C' ;transmit, for C measurement call Send bsf INTCON,GIE ;enable global interrupt bit goto start ;restart ErrorDetect bcf STATUS,RP0 ;disable TMR0 bcf INTCON,T0IE bcf INTCON,T0IF call AnalogOff ;turn analog off bcf flags,F_ERROR ;clear error flag bcf INTCON,GIE ;disable all interrupts movlw 'E' ;transmit, for C measurement call Send bsf INTCON,GIE ;enable global interrupt bit goto start ;restart ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- RS232 Transmit Routine -* ;*- Borrowed from AN593, "Serial Port Routines Without Using the RTCC" -* ;*- Author: Stan D'Souza -* ;*- This is the routine that interfaces directly to the hardware -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Transmit bcf STATUS,RP0 movwf txreg bcf tx ;send start bit movlw baudconst movwf delay movlw 0x9 movwf count txbaudwait decfsz delay goto txbaudwait movlw baudconst movwf delay decfsz count goto SendNextBit movlw 0x9 movwf count bsf tx ;send stop bit return SendNextBit rrf txreg btfss STATUS,C goto Setlo bsf tx goto txbaudwait Setlo bcf tx goto txbaudwait ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Generic Transmit Routine -* ;*- Sends what is currently in the W register and accumulator ACCc -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Send call Transmit call delay1 ;delay between bytes movf ACCcHI,W ;transmit high resistance byte call Transmit call delay1 ;delay between bytes movf ACCcMID,W ;transmit mid resistance byte call Transmit call delay1 ;delay between bytes movf ACCcLO,W ;transmit low resistance byte call Transmit call delay1 ;delay between bytes return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Interrupt Service Routines -* ;*--------------------------------------------------------------------------* ;**************************************************************************** ServiceInterrupts movwf W_TEMP ;Pseudo push instructions swapf STATUS,W bcf STATUS,RP0 movwf STATUS_TEMP movf TMR0,W movwf Ttemp btfsc INTCON,T0IF ;Service Timer 0 overflow call ServiceTimer btfsc PIR1,CMIF ;Stops Timer0, Records Value call ServiceComparator btfsc INTCON,RBIF ;Service pushbutton switch call ServiceKeystroke ;Starts a measurement bcf STATUS,RP0 swapf STATUS_TEMP,W ;Pseudo pop instructions movwf STATUS swapf W_TEMP,F swapf W_TEMP,W retfie ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Borrowed from AN552, "Implementing Wake-up on Key Stroke" -* ;*- Author: Stan D'Souza -* ;*--------------------------------------------------------------------------* ;**************************************************************************** ServiceKeystroke bcf INTCON,RBIE ;disable interrupt comf PORTB,W ;read PORTB bcf INTCON,RBIF ;clear interrupt flag andlw B'01000000' btfsc STATUS,Z goto NotSwitch call delay16 ;de-bounce switch for 16msec comf PORTB,W ;read PORTB again call KeyRelease ;check for key release bsf flags,BEGIN return NotSwitch ;detected other PORTB pin change bcf INTCON,RBIF ;reset RBI interrupt bsf INTCON,RBIE return KeyRelease call delay16 ;debounce switch comf PORTB,W ;read PORTB bcf INTCON,RBIF ;clear flag bsf INTCON,RBIE ;enable interrupt andlw B'01000000' btfsc STATUS,Z ;key still pressed? return ;if no, then return sleep ;else, save power bcf INTCON,RBIE ;disable interrupts comf PORTB,W ;read PORTB bcf INTCON,RBIF ;clear flag goto KeyRelease ;try again ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- ISR to service a Timer0 overflow -* ;*--------------------------------------------------------------------------* ;**************************************************************************** ServiceTimer incf TimeMID,F ;increment middle Time byte btfsc STATUS,Z ;if middle overflows, incf TimeHI,F ;increment high Time byte btfsc TimeHI,EMPTY ;check if component is connected bsf flags,F_ERROR ;set error flag bcf INTCON,T0IF ;clear TMR0 interrupt flag return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- ISR to service a Comparator interrupt -* ;*--------------------------------------------------------------------------* ;**************************************************************************** ServiceComparator bcf STATUS,RP0 ;select bank 0 btfss PORTB,WHICH ;detect which measurement, R or C? goto capcomp btfss CMCON,C1OUT ;detect if R ckt has interrupted goto scstop goto scend capcomp btfsc CMCON,C2OUT ;detect if C ckt has interrupted goto scend scstop bcf INTCON,T0IE ;disable TMR0 interrupts bcf INTCON,T0IF movf Ttemp,W movwf TimeLO bsf flags,DONE ;set DONE flag scend bcf PIR1,CMIF ;clear comparator interrupt flag return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Turn Comparators and Vref On -* ;*--------------------------------------------------------------------------* ;**************************************************************************** AnalogOn bcf STATUS,RP0 ;select bank 0 movlw 0x02 ;turn comparators on, mode 010 movwf CMCON ;4 inputs multiplexed to 2 comparators bsf STATUS,RP0 ;select bank 1 movlw 0x0F ;make PORTA<3:0> all inputs movwf TRISA bsf VRCON,VREN bcf STATUS,RP0 ;select bank 0 call delay20 ;20msec delay movf CMCON,F ;clear comparator mismatch condition bcf PIR1,CMIF ;clear comparator interrupt flag bsf STATUS,RP0 bsf PIE1,CMIE ;enable comparator interrupts bcf STATUS,RP0 bsf INTCON,PEIE ;enable peripheral interrupts bcf flags,F_ERROR clrf TMR0 ;clear TMR0 counter nop nop bcf INTCON,T0IF ;clear TMR0 interrupt flag bsf INTCON,T0IE ;enable TMR0 interrupts return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Turn Comparators and Vref Off -* ;*--------------------------------------------------------------------------* ;**************************************************************************** AnalogOff bcf STATUS,RP0 bcf INTCON,PEIE movlw 0x80 ;reset PORTB value movwf PORTB bsf STATUS,RP0 ;select bank 1 bcf PIE1,CMIE ;disable comparator interrupts clrf TRISA ;set PORTA pins to outputs, discharge RC ckt movlw 0x60 ;set PORTB 7,4-0 as outputs, 6,5 as inputs movwf TRISB bcf VRCON,VREN ;disable Vref bcf STATUS,RP0 ;select bank 0 movlw 0x07 movwf CMCON ;disable comparators call delay20 ;20msec delay movf CMCON,F ;clear comparator mismatch condition bcf PIR1,CMIF ;clear comparator interrupt flag bcf INTCON,T0IF ;clear Timer0 interrupt flag call vlong ;long delay to allow capacitors to discharge call vlong call vlong return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Swap Time to Accumulator a -* ;*--------------------------------------------------------------------------* ;**************************************************************************** SwapTtoA bcf STATUS,RP0 movf TimeHI,W movwf ACCaHI movf TimeMID,W movwf ACCaMID movf TimeLO,W movwf ACCaLO clrf TimeHI clrf TimeMID clrf TimeLO return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Transmit the Boot Message -* ;*--------------------------------------------------------------------------* ;**************************************************************************** BootMSG bcf STATUS,RP0 ;select bank 0 msg movlw HIGH Table ;init the PCH for a table call movwf PCLATH movf offset,W ;move table offset into W call Table ;get table value call Transmit ;transmit table value call delay1 ;delay between bytes decfsz offset,F ;check for end of table goto msg movlw 0x10 ;reset table offset movwf offset return ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Delay Routines -* ;*--------------------------------------------------------------------------* ;**************************************************************************** vlong movlw 0xff ;very long delay, approx 200msec movwf msb goto d1 delay20 ;20 msec delay movlw .26 movwf msb goto d1 delay16 ;16 msec delay movlw .21 movwf msb goto d1 delay1 ;approx 750nsec delay movlw .1 movwf msb d1 movlw 0xff movwf lsb d2 decfsz lsb,F goto d2 decfsz msb,F goto d1 return ;____________________________________________________________________________ org 0x200 ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Table for Boot Message -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Table ;boot message "PICMETER Booted!" addwf PCL ;add W to PCL retlw 0 retlw '!' retlw 'd' retlw 'e' retlw 't' retlw 'o' retlw 'o' retlw 'B' retlw ' ' retlw 'R' retlw 'E' retlw 'T' retlw 'E' retlw 'M' retlw 'C' retlw 'I' retlw 'P' ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- 24-bit Addition -* ;*- -* ;*- Uses ACCa and ACCb -* ;*- -* ;*- ACCa + ACCb -> ACCb -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Add24 movf ACCaLO,W addwf ACCbLO ;add low bytes btfsc STATUS,C ;add in carry if necessary goto A2 A1 movf ACCaMID,W addwf ACCbMID ;add mid bytes btfsc STATUS,C ;add in carry if necessary incf ACCbHI movf ACCaHI,W addwf ACCbHI ;add high bytes retlw 0 A2 incf ACCbMID btfsc STATUS,Z incf ACCbHI goto A1 ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Subtraction ( 24 - 24 -> 24 ) -* ;*- -* ;*- Uses ACCa, ACCb, ACCd -* ;*- -* ;*- ACCa -> ACCd, -* ;*- 2's complement ACCa, -* ;*- call Add24 ( ACCa + ACCb -> ACCb ), -* ;*- ACCd -> ACCa -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Sub24 movf ACCaHI,W ;Transfer ACCa to ACCd movwf ACCdHI movf ACCaMID,W movwf ACCdMID movf ACCaLO,W movwf ACCdLO call compA ;2's complement ACCa call Add24 ;Add ACCa to ACCb movf ACCdHI,W ;Transfer ACCd to ACCa movwf ACCaHI movf ACCdMID,W movwf ACCaMID movf ACCdLO,W movwf ACCaLO retlw 0 ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Multiply ( 24 X 24 -> 56 ) -* ;*- -* ;*- Uses ACCa, ACCb, ACCc, ACCd -* ;*- -* ;*- ACCa * ACCb -> ACCb,ACCc 56-bit output -* ;*- with ACCb (ACCbHI,ACCbMID,ACCbLO) with 24 msb's and -* ;*- ACCc (ACCcHI,ACCcMID,ACCcLO) with 24 lsb's -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Mpy24 call Msetup mloop rrf ACCdHI ;rotate d right rrf ACCdMID rrf ACCdLO btfsc STATUS,C ;need to add? call Add24 rrf ACCbHI rrf ACCbMID rrf ACCbLO rrf ACCcHI rrf ACCcMID rrf ACCcLO decfsz temp ;loop until all bits checked goto mloop retlw 0 Msetup movlw 0x18 ;for 24 bit shifts movwf temp movf ACCbHI,W ;move ACCb to ACCd movwf ACCdHI movf ACCbMID,W movwf ACCdMID movf ACCbLO,W movwf ACCdLO clrf ACCbHI clrf ACCbMID clrf ACCbLO retlw 0 ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- Division ( 56 / 24 -> 24 ) -* ;*- -* ;*- Uses ACCa, ACCb, ACCc, ACCd -* ;*- -* ;*- 56-bit dividend in ACCb,ACCc ( ACCb has msb's and ACCc has lsb's) -* ;*- 24-bit divisor in ACCa -* ;*- quotient is stored in ACCc -* ;*- remainder is stored in ACCb -* ;*--------------------------------------------------------------------------* ;**************************************************************************** Div24 call Dsetup dloop bcf STATUS,C rlf ACCcLO ;Rotate dividend left 1 bit position rlf ACCcMID rlf ACCcHI rlf ACCbLO rlf ACCbMID rlf ACCbHI btfsc STATUS,C ;invert carry and exclusive or with the goto clear ;msb of the divisor then move this bit btfss ACCaHI,msb_bit ;into the lsb of the dividend incf ACCcLO goto cont clear btfsc ACCaHI,msb_bit incf ACCcLO cont btfsc ACCcLO,lsb_bit ;check the lsb of the dividend goto minus call Add24 ;if = 0, then add divisor to upper 24 bits goto check ;of dividend minus call Sub24 ;if = 1, then subtract divisor from upper ;24 bits of dividend check decfsz temp,f ;do 24 times goto dloop bcf STATUS,C rlf ACCcLO ;shift lower 24 bits of dividend 1 bit rlf ACCcMID ;position left rlf ACCcHI btfsc ACCbHI,msb_bit ;exlusive or the inverse of the msb of the goto w1 ;dividend with the msb of the divisor btfss ACCaHI,msb_bit ;store in the lsb of the dividend incf ACCcLO goto wzd w1 btfsc ACCaHI,msb_bit incf ACCcLO wzd btfss ACCbHI,msb_bit ;if the msb of the remainder is set and goto wend btfsc ACCaHI,msb_bit ;the msb of the divisor is not goto wend call Add24 ;add the divisor to the remainder to correct ;for zero partial remainder wend retlw 0 ;quotient in 24 lsb's of dividend ;remainder in 24 msb's of dividend Dsetup movlw 0x18 ;loop 24 times movwf temp retlw 0 ;____________________________________________________________________________ ;**************************************************************************** ;*--------------------------------------------------------------------------* ;*- 2's Complement -* ;*- -* ;*- Uses ACCa -* ;*- -* ;*- Performs 2's complement conversion on ACCa -* ;*--------------------------------------------------------------------------* ;**************************************************************************** compA comf ACCaLO ;invert all bits in accumulator a comf ACCaMID comf ACCaHI incf ACCaLO ;add one to accumulator a btfsc STATUS,Z incf ACCaMID btfsc STATUS,Z incf ACCaHI retlw 0 ;____________________________________________________________________________ END
