MP3, MP4 Multimedya entegre bilgileri
| Ocak 11, 2020 Tarihinde güncellendi
Günümüzde sık kullanılan Mp3, mp4 gibi ses video oynatıcı cihazların devrelerinde bulunan çok fonksiyonlu (ses kodek, video kodek tft lcd sürücülü vs..) multimedya entegre datasheet bilgileri bağlantı şemaları özellikle teknik servislerde tamir işleri için çok işe yarayabilecek şemalar bağlantı bilgileri bulunuyor.
ATJ2180 pin out bağlantı şeması
ATJ2180-datasheet
ATJ2180-pinout-schematic ATJ2180 datsheet, ATJ2180, ATJ2180 schematic
Avid A1569 Flash Media Player FM Transmitter Datasheet
avid-a1569-flash-media-player-with-fm-transmitter
A1569 integrates high bandwidth USB2.0 for 480 mbps transfer rate. With high bandwidth, user can easily download music and upload voice recordings within minutes. Firmware can be upgradeable from USB port. For storage, NAND-type Flash is supported. It can support with 8-bit, 16-bit data bus width NAND Flash or it can use 2 pieces 8-bit NAND Flash to achieve high bandwidth. It can use up to 4 pieces to expand memory storage capacity. 8 bit Error detection and correction is generated for on board NAND Flash. A1569 supports card reader function for SD/MMC card. MP3(up to 384Kbps), MP2, WMA(up to 320Kbps) and ASF
avid-a1569-blok-diagram
Pin Configuration LQFP Package
Pin Number Pin NameAttrib.Description
1 HPVDDANAHeadphone power
2 HPRINNANAHeadphone Right Channel In
3 HPLINNANAHeadphone Left Channel In
4 HPBYPANAHeadphone Bypass Capacitor
5 AVCC3ANADAC Power Supply
6 AVRC1ANADAC Voltage Reference Capacitor
7 LOUTANADAC Left Channel Out
8 COUTANADAC Voltage Reference Capacitor
9 ROUTANADAC Right Channel Out
10 AVRC2ANAReference bias capacitor
11 AGND3ANADAC Ground
12 GNDADANAKey scan & Voice Recording Ground
13 CVTIANAADC Top reference voltage
14 OPT1ANAADC Optional Channel 1 In
15 OPT2ANAADC Optional Channel 2 In
16 VDDADANAKey scan & Voice Recording Power
17 MICNANAMic positive input
18 MICPANAMic negative input
19 VDDMICANAMIC regulated power(3.3 to 2.8)
20 TVDD18DANALinear regulator 1.8V output
21 TVDD33RANALinear regulator 3.3V output
22 TVSS33RANALinear regulator Ground
23 HTVDD50ANAUSB 5V power
24 X1ANA32.768 K OSC
25 X2ANA32.768K OSC
26 VPOUTANARTC /Ring OSC power
27 VBYANABattery in
28 VSSDCANADC2DC analog ground
29 SHDN_SOCANADC2DC Hi enable power down and output will be pull low to zero
30 CP18ANACompensation connection
31 FB18ANADC2DC feedback
32 VOUT18ANADC2DC 1.8V output
33 PGND18ANADC2DC 1.8V driver Ground
34 LX18ANAConnection to the external inductor for 1.8V
35 LX33ANAConnection to the external inductor for 3.3V
36 PGND33ANADC2DC driver Ground
37 VOUT33ANADC2DC output
38 FB33ANADC2DC feedback
39 CP33ANACompensation connection
40 VSSCOPWRDigital Core Ground
41 VDDCOPWRDigital Core Power Supply
42 SEG27/GPIO7ANA/I/O(1) LCM SEGMENT27 (2)GPIO port 7
43 SEG26/GPIO4ANA/I/O(1)LCM SEGMENT DATA26(2)GPIO port 4
44 SEG25/GPIO5ANA/I/O(1) LCM SEGMENT DATA25(2)GPIO port 5
45 SEG24/FLCE2#/GPIO24ANA/I/O(1) LCM SEGMENT DATA24(2)Flash Memory Chip Enable 2; (3) GPIO port 24
46 SEG23/FLCE3#/GPIO23ANA/I/O(1) LCM SEGMENT DATA23(2)Flash Memory Chip Enable 3; (2) GPIO port 23
47 VSSIOPWRDigital IO Ground
48 SEG22/FLRB1#/GPIO22ANA/I/O(1) LCM DATA22(2) Flash Memory Ready/Busy input 1; (2) GPIO port 22
49 SEG21/GPIO21ANA/I/O(1) LCM SEGMENT DATA 21 (2) GPIO port 21
50 SEG20/GPIO20ANA/I/O(1) LCM SEGMENT DATA20 (2) GPIO port 20
51 SEG19/LCCS#/GPIO19ANA/I/O(1) LCM SEGMENT DATA 19 (2) LCM Chip Select (3) GPIO port 19
52 SEG18/LCA0/GPIO18ANA/I/O(1) LCM SEGMENT DATA 18 (2) LCM Address 0 (3) GPIO port 18
53 SEG17/LCSI/GPIO17ANA/I/O(1) LCM SEGMENT DATA 17 (2) LCM Serial Data (3) LCM Read Enable (Intel) (4) LCM Enable (Motorola)(5)GPIO17
54 SEG16/LCSCL/GOIP16ANA/I/O(1) LCM SEGMENT DATA 16 (2) LCM Serial Clock (3) LCM Write Enable (Intel) (4) LCM R/W# (Motorola)(5)GPIO16
55 VDDIOPWRDigital IO Power Supply
56 SEG15//FLD15/UA15/GPIO15ANA/I/O(1) LCM SEGMENT DATA15(2) FLASH DATA15 (3) 8051 Address 15 (4) GPIO port 15
57 SEG14/FLD14/UA14/GPIO14ANA/I/O(1) LCM SEGMENT DATA 14(2) FLASH DATA14(3) 8051
Address 14 (4) GPIO port 14
58 SEG13/FLD13/UA13ANA/I/O(1) LCM SEGMENT DATA 13(2) FLASH DATA13(3) 8051 Address 13 (4) GPIO port 13
59 SEG12/FLD12/UA12ANA/I/O(1) LCM SEGMENT DATA 12(2) FLASH DATA12(3) 8051 Address 12 (4) GPIO port 12
60 SEG11/FLD11/UA11ANA/I/O(1) LCM SEGMENT DATA 11(2) FLASH DATA11(3) 8051 Address 11 (4) GPIO port 11
61 SEG10/FLD10/UA10ANA/I/O(1) LCM SEGMENT DATA 10(2) FLASH DATA10(3) 8051 Address 10 (4) GPIO port 10
62 SEG9/FLD9/UA9ANA/I/O(1) LCM SEGMENT DATA 9(2) FLASH DATA9(3) 8051 Address 9 (4) GPIO port 9
63 SEG8/FLD8/UA8ANA/I/O(1) LCM SEGMENT DATA 8(2) FLASH DATA8(3) 8051 Address 8 (4) GPIO port 8
64 VSSIOPWRDigital IO Ground
65 VLCDPWRLCD Power REFERENCE 5V TOLERENCE
66 SEG7/UAD7ANA/I/O(1) LCM SEGMENT DATA 7 (2)8051 Address/Data 7
67 SEG6/UAD6ANA/I/O(1) LCM SEGMENT DATA 6 (2)8051 Address/Data 6
68 SEG5/UAD5ANA/I/O(1) LCM SEGMENT DATA 5 (2) 8051 Address/Data 5
69 SEG4/UAD4ANA/I/O(1) LCM SEGMENT DATA 4 (2)8051 Address/Data 4
70 SEG3/UAD3ANA/I/O(1) LCM SEGMENT DATA3 (2)8051 Address/Data 3
71 SEG2/UAD2ANA/I/O(1) LCM SEGMENT DATA 2 (2) 8051 Address/Data 2
72 SEG1/UAD1ANA/I/O(1) LCM SEGMENT DATA 1 (2)8051 Address/Data 1
73 SEG0/UAD0ANA/I/O(1) LCM SEGMENT DATA 0 (2)8051 Address/Data 0
74 COM3/URE#ANA/O(1) LCD COMMON DATA 3 (2)8051 Read Enable
75 COM2/UALEANA/O(1) LCD COMMON DATA 2 (2)8051 Address Latch Enable
76 COM1/UWE#ANA/O(1) LCD COMMON DATA 1 (2)8051 Write Enable
77 COM0/ROMOE#ANA/O(1) LCD COMMON DATA 0 (2) 8051 External ROM Output Enable
78 VSSCOPWRDigital Core Ground
79 VDDCOPWRDigital Core Power Supply
80 VSSCOPWRDigital Core Ground
81 VDDIOPWRDigital IO Power Supply
82 FLD7I/OFlash Memory Data 7
83 FLD6I/OFlash Memory Data 6
84 FLD5I/OFlash Memory Data 5
85 FLD4I/OFlash Memory Data 4
86 FLD3/SDD3I/O(1) Flash Memory Data 3 (2) SD Card Data 3
87 FLD2/SDD2I/O(1) Flash Memory Data 2 (2)SD Card Data 2
88 FLD1/SDD1I/O(1) Flash Memory Data 1 (2) SD Card Data 1
89 FLD0/SDD0I/O(1) Flash Memory Data 0 (2) SD Card Data 0
90 VSSIOPWRDigital IO Ground
91 FLCLE/GPIO13OFlash Memory Command Latch Enable
92 FLALE/GPIO12OFlash Memory Address Latch Enable
93 SDCLKOSD/MMC Clock
94 FLRE#/SDCMDO/IO(1) Flash Memory Read Enable (2) SD Card Command
95 FLCE1#/GPIO11OFlash Memory Chip Enable 1
96 FLCE0#/GPIO10OFlash Memory Chip Enable 0
97 VDDIOPWRDigital IO Power Supply
98 VSSIOPWRDigital IO Ground
99 FLRB0#IFlash Memory Ready/Busy input 0
100 FLWE#/GPIO9OFlash Memory Write Enable
101 FLWP#GPIO8OFlash Memory Write Protect
102 ICSDAI/OI2C Serial Data
103 ICSCLI/OI2C Serial Clock
104 URXDI(1)8051 UART RXD0
105 UTXDO(1) 8051 UART TXD0
106 RESET#ISystem Reset
107 GPIO6/EXTINT#I/O(1) GPIO port 6 (2) External Interrupt
108 GPIO3/OPT3I/OGPIO port 3/OPT3 input
109 GPIO2I/OGPIO port 2
110 GPIO1I/OGPIO port 1
111 GPIO0I/OGPIO port 0
112 XINICrystal (12MHz) Input
113 XOUTOCrystal (12MHz) Output
114 VSSCOPWRDigital Core Ground
115 VDDCOPWRDigital Core Power Supply
116 VSSPLPWRPLL Ground
117 VDDPLPWRPLL Power Supply
118 DMANAPHY Differential Minus
119 VSSPWRPHY Digital Ground
120 DPANAPHY Differential Plus
121 REXTANAPHY External Resistor 6K
avid a1569, a1569 datasheet
ATJ2073 LQFP128 Datasheet pinout
The ATJ2073 is a single-chip highly-integrated digital music system solution for devices such as dedicated audio players, PDAs, and cell phones. It includes an audio decoder with a high performance DSP with embedded RAM, ADPCM/AG record capabilities and USB interface for downloading music and uploading voice recordings. ATJ2073 also provides an interface to S/PDIF audio data input, flash memory, LED/LCD, button and switch inputs, headphone, and microphone, and FM radio control.
The ATJ2073’s programmablearchitecture supports the MP3 and other digital audio standards. For devices like USB Flash Disk, the ATJ2073 can act as a USB mass storage slave device to personal computer system. The ATJ2073 has low power consumption to allow long battery life and an efficient flexible on-chip DC-DC converter that allows many different battery configurations, including 1xAA, 1xAAA, 2xAA,2xAAA.
ATJ2073-LQFP128-datasheet
ATJ2115F pin out bağlantı şeması
ATJ2115F-datasheet-pinout
ATJ2115F-schematic-pinout ATJ2115F datasheet, ATJ2115F schematic, ATJ2115F
Rock chip RK2608A Pinout bağlantı şeması
Rockchip-RK2608A-datasheet
Rockchip RK2608A schematic Rock chip RK2608A, Rockchip, RK2608A datasheet, RK2608A schematic
ACU7512 Bağlantı şeması
ACU7512 Bir çok mp4, mp3 oynatıcıda kullanılıyor usb, sd kart vb gibi bir çok
multi medya özelliği var tam data sheet dosyası verilmiyor ama bağlantı
şeması az çok işe yarar
ACU7512-datasheet
ATJ2085 Datasheet pinout
atj2085-datasheet-pinout
ATJ2085 is a single-chip for flash-based digital music player. It includes an audio decoder with a high performance DSP, ADPCM record capabilities and USB interface for downloading music and uploading voice recordings. ATJ2085 also provides an interface to flash memory, LED, button and switch inputs, headphone, and microphone, and FM radio input and control. ATJ2085’s programmable architecture supports the MP3, WMA
For devices like USB-Disk, ATJ2085 can act as a USB mass storage slave device to personal computer system. Its low power consumption allows a long battery life, and an efficient flexible on-chip DC-DC converter allows many different battery configurations, including 1xAA, 1xAAA, 2xAA, 2xAAA and Li-Ion. Built-in Sigma-Delta DAC & a headphone driver to directly drive low impedance headphones. The ADC includes inputs for both Microphone and Analog Audio in to support voice recording and FM radio integration features.
ATJ2111L pin out bağlantı şeması
ATJ2111L-datasheet-pinout
ATJ2111L-schematic-pinout ATJ2111L datasheet, ATJ2111L, ATJ2111L schematic
mp3-mp4-multimedya-entegre-bilgileri
Sharp LM64P89 LM64P839
Display type:Sharp LM64P89 & LM64P839
Inverter no.:40900097
Cable no.:72560100
System:686LCD with FPUM-2 and AC-2
Display driver:SHA LM64K836
Status:Verified
Display ConnectorJPLCD50-pole connectorRemarks
Term. #FunctionPinConnector
1S11FLMScan start-up signal
2CP110LPInput data latch signal
3CP213SHFCLKData input clock signal
4DISP8CPO1Display control signal
5VDD2VCCPower supply for logic and LCD (+5V)
6VSS38GNDGround
potential
7VEE40VEEpower supply for LCD (-)
8DU019P3Display data signal (Upper half)
9DU118P2
10DU216P1
11DU315P0
12DL025P7Display data signal (Lower half)
13DL124P6
14DL222P5
15DL321P4
AK1025 bağlantı şeması
AK1025_schematic_datasheet
AK1025 datasheet, AK1025
ATJ2097 pinout cpu bağlantı şeması
ATJ2097-datasheet-schematic-pinout
ATJ2097-schematic-pinout ATJ2097 datasheet, ATJ2097 schematic, ATJ2097
ATJ2087 Pinout bağlantı şeması
ATJ2087-datasheet-ATJ2087-pinout
ATJ2087 diagram ATJ2087 pinout ATJ2087 datasheet, ATJ2087 pinout, ATJ2087
ACU7502 Datasheet (pin connection)
acu7502-datasheet
acu7502 datasheet, acu7502
ATJ2001 LQFP176 bağlantı şeması
ATJ2001 LQFP176 pin
ATJ2001-datasheet-PDA-MP3-Decoder
ATJ2001, LQFP176, ATJ2001 datasheet, LQFP176 datasheet
ATJ2091 pinout bağlantı şeması
ATJ2091-datasheet-pinout-schematic
ATJ2091 schematic ATJ2091 pinout ATJ2091 schematic, ATJ2091 pinout, ATJ2091 datasheet
ATJ2007 Mcu modül şeması
atj2007-datasheet-pinout-schematic
ATJ2007 pin out ATJ2007 datasheet, ATJ2007 schematic, ATJ2007
acu7502-datasheet
ATJ2055 Datasheet
ATJ2055 Datasheet
atj2055-datasheet
ATJ2063N Datasheet
ATJ2063N Data sheet
atj2063n-datasheet
ACU7515 cpu bağlantı şeması
ACU7515-cpu-module-datasheet
ATJ2051 Datasheet
ATJ2051 Data sheet
atj2051-datasheet
ATJ2051X is a single-chip for flash-based digital music player. It includes an audio decoder with a high performance DSP, ADPCM record capabilities and USB interface for downloading music and uploading voice recordings. ATJ2051X also provides an interface to flash memory, button and switch inputs, headphone, and microphone. ATJ2051X’s programmable architecture supports the MP3, WMA and other digital audio standards.
For devices like USB-Disk, ATJ2051X can act as a USB mass storage slave device to personal computer system. Its low power consumption allows a long battery life, and an efficient flexible on-chip DC-DC converter allows many different battery configurations, including 1xAA, 1xAAA, 2xAA, 2xAAA and Li-Ion. Built-in Sigma-Delta DAC & a headphone
driver to directly drive low impedance headphones. The ADC includes inputs for both Microphone and Analog Audio in to support voice recording features. Thus, the ATJ2051X provides a true ‘ALL-IN-ONE’ solution that is ideally suited for highly optimized digital audio
players with mass storage function.
STMP36XX BGA Pinout uygulama şeması
stmp36xx-bga-169p-schematic-stmp36-datasheet
stmp36xx-bga-schematic-pin-out stmp36xx datasheet, stmp36xx schematic, stmp36xx bga
ATJ2093 Pinout bağlantı şeması
atj2093-datsheet-schematic-pinout
atj2093-cpu-schematic-pinout atj2093 datsheet, atj2093 schematic, atj2093 pinout
ACU7517 bağlantı şeması
ACU7517-datasheet
ATJ2092H Data Sheet pinout
ATJ2092H-Data-Sheet-pinout
ATJ2092H Datasheet pinout
ATJ2092H is a new generation single-chip highly-integrated digital multimedia SOC for devices such as dedicated audio players, photo viewers, PDAs. It includes audio codec, image and video decoding engine, a high performance 2 core (DSP and MCU) structure with embedded RAM and ROM, digital record capabilities and USB interface for downloading and uploading. ATJ2092H also provides an interface to flash memory,
LED/LCD/OLED, button and switch inputs, headphones, microphone.
ATJ2092H contains a high performance DSP, which can easily be programmed to support many kinds of digital audio standards such as MP3, WMA, etc. As storage devices ATJ2092H can act as a USB mass storage slave device to personal computer system and meanwhile ATJ2092H can be applied as MTP. ATJ2092H has low power consumption
ACU75032 bağlantı şeması
ACU75032-A3-datasheet
Rockchip RK2606A Pinout bağlantı şeması
Rockchip-RK2606A-datasheet
Rock chip-RK2606A-pin-out Rockchip RK2606A, RK2606A datasheet, RK2606A schematic
Actions ACU7503 Datasheet (pin connections)
acu7503-datasheet
Instruction set of MCU compatible with Z80, Internal SRAM access time<7ns, MROM access time<16ns, Accurate Clock Management Unit, supplies 24MHz OSC, Energy saving Power Management Unit, supports 1xAA, 1xAAA, 2-channel DMA, 1-channel Counter/Timer Controller and Interrupt Controller, Support USB 2.0 high speed, acting as mass storage deviceSupport up to 4(pcs)*64M-4G bytes Nand type SLC/MLC Flash, Built-in Key Scan Circuit and GPIOs, Built-in Stereo Sigma-Delta DAC and ADC Digital voice recording at ultra low 4.4 or 8Kbps with Actions Speech Algorithm, upport FM Radio input and 32 levels volume control, Support extended low frequency crystal to generalize RTC 0.18um 1P5M CMOS process and packaged at LQFP-80(10*10mm)
Pin No. Pin Name I/O Type Driver Capacity Reset Default Short Description
1 UVCC PWR / / Power supply for USB
2 URES AO / / USB precision Resistor
3 USBGND PWR / / USB ground
4 USBDP A / H USB data plus
5 USBDM A / H USB data minus
6 USBVDD PWR / / USB power
7 PAVCC PWR / / Power supply for Power Amplifier
8 AOUTR AO / / Int. PA right channel analog output
9 AOUTL AO / / Int. PA left channel analog output
10 PAGND PWR / / Power Amplifier ground
11 VRDA AO / / Bypass capacitor connect pin for int. DAC Reference
voltage
12 MICIN AI / / Microphone pre-amplifier input
13 VMIC PWR / / Power supply for Microphone
14 FMINL AI / / Left channel of FM line input
15 FMINR AI / / Right channel of FM line input
16 AGND PWR / / Analog ground
17 AVCC PWR / / Power supply of analog
18 VREFI AI / / Voltage reference input
19 AVDD PWR / / Analog core power pin
20 VDD PWR / Z Core power
21 VCC PWR / / IO power
22 LRADC1 AI / / Low resolution A/D input 1
23 VDDFB AI / / VDD feedback
24 VCC PWR / / IO power
25 HOSCI AI / / High frequency crystal OSC input
26 HOSCO AO / / High frequency crystal OSC output
27 BAT I / / Battery voltage input.
28 GPIO_B0 BI 2mA Z Bit0 of General Purpose I/O port B
KEYI0 I H Bit0 of key scan circuit input
CE3- O H Chip enable 3
29 GPIO_B2 BI 2mA Z Bit2 of General Purpose I/O port B
KEYI2 I H Bit2 of key scan circuit input
CE4- O H Chip enable 4.
30 LXVDD PWR / / VDD DC-DC pin
31 GND PWR / / Ground
32 NGND PWR / / NMOS ground
33 LXVCC PWR / / VCC DC-DC pin
34 CE2- O NF_PAD H Ext. memory chip enable 2
35 CE1- O NF_PAD H Ext. memory chip enable 1
36 CE5- O 4mA H Ext. memory chip enable 5
GPO_A3 BI / Bit3 of General Purpose Output port A
37 GPIO_G0 BI 2mA Z Bit0 of General Purpose I/O port G
MMC_CMD O / Command/Respond of SD/MMC
38 VDD PWR / / Digital core power
39 RB- I 4mA H Nand Flash Ready/Busy status input
40 GPO_A1 O 4mA L Bit1 of General Purpose Output port A
ICECK I / Clock input of DSU
41 GPO_A2 O 4mA L Bit2 of General Purpose Output port A
ICEDO O / Data output of DSU
42 GPO_A0 O 4mA 0 Bit0 of General Purpose Output port A
ICEDI I / Data input of DSU
43 ICEEN- I 4mA / DSU enable (active low)
44 ICERST- I 4mA / DSU reset (active low)
45 GPIO_B4 BI 2mA Z Bit4 of General Purpose I/O port B
KEYO0 O / Bit0 of key scan circuit output
46 GPIO_B5 BI 2mA Z Bit5 of General Purpose I/O port B
KEYO1 O / Bit1 of key scan circuit output
47 RESET- I USCU H System reset input (active low)
48 VCC PWR / / Digital power pad
49 D7 BI NF_PAD L Bit7 of ext. memory data bus
50 D6 BI NF_PAD L Bit6 of ext. memory data bus
51 D5 BI NF_PAD L Bit5 of ext. memory data bus
52 D4 BI NF_PAD L Bit4 of ext. memory data bus
53 D3 BI NF_PAD L Bit3 of ext. memory data bus
54 D2 BI NF_PAD L Bit2 of ext. memory data bus
55 GND PWR / / Ground
56 D1 BI NF_PAD L Bit1 of ext. memory data bus
57 D0 BI NF_PAD L Bit0 of ext. memory data bus
58 MWR O NF_PAD H Ext. memory write strobe
59 MRD- O NF_PAD H Ext. memory read strobe
60 CLE O NF_PAD L Command Latch Enable fo NandFlash
61 ALE O NF_PAD L Address latch enable for NAND flash
62 GPIO_C1 BI 2mA OD Bit1 of General Purpose I/O port C
I2C_SDA O / I2C Serial data (Open drain)
SIRQ- I / Ext. interrupt request input
63 GPIO_C0 BI 2mA OD Bit0 of General Purpose I/O port C
I2C_SCL O / I2C serial clock (Open drain)
64 VDD PWR / / Digital core power
Yayım tarihi: 2010/10/01 Etiketler: , , ,
