Anahtarlamalı doğrusal amplifikatör devresi
| Mayıs 29, 2023 Tarihinde güncellendi
Anahtarlamalı anfi devresinin tüm detayları tasarım aşamaları devredeki tüm bölümlerin hesaplanması hakkında detaylı bilgi (ingilizce) bulunuyor devre 8ohm hoparlör ile 100.. 300 watt arası güç veriyor kaliteli ve ayrıntılı bir çalışma ayrıca protel ile hazırlanmış pcb ve şema (PBC.ddb, amp.DDB) çizimleride bulunuyor
Switch-Mode-Assisted-Linear-Amplifier-SMALA
The Switch-Mode Assisted Linear Amplifier (SMALA) is a hybrid amplifier topology, which combines a linear (analogue) and a switch-mode (digital) amplifier, to produce an amplifier with the advantages of both circuits while minimising the disadvantages. This topology is aimed at audio power amplifiers where both high efficiency and high fidelity are required. This thesis aims to expand the existing technology to produce a high power amplifier suitable for use in the public address industry.
Initially, the prior work in the field is presented to give the relevant background information and to underline the current state of the technology. The design is then analysed to yield the most suitable topology for a high power application. Following this, a detailed description of an initial prototype and the final design is given.
The results from the testing of both the prototype and final design are discussed, with recommendations made for future improvements. The final design was capable of high output power at high efficiency, with ЗООW at 86% efficiency measured. The amplifier produced more distortion then expected, with О.З5% distortion at this power level.
Dosya ve detaylar:innovexpo.itee.uq.edu.au/2003/exhibits/s354194/
anahtarlamali-dogrusal-amplifikator-devresi
Yayım tarihi: 2009/12/28 Etiketler: , , , ,
