Daha önce Talking Electronics Sitesinde yeni paylaşılan 200 adet transistörlü devre için hazırlanan kitapdan bahsetmiştim. Yazar bu tip bedava kitaplarıpaylaşmaya devam ediyor.
555 devre kitabında bulunan devrelerin bir çoğu basit çok az eleman ile kuruluyor osilatör, zamanlama, led, motor kontrol ve daha fazlası bir çok uygulama var
555 DEVRELERİ İÇERİK LİSTESİ | |
Active High Trigger Active Low Trigger Alarm Sounds (4 sounds) Alarm 4-Zone Amplifier using 555 Animated Display Audio Frequency Meter Automatic Curtain Closer Astable Multivibrator Basic 555 Oscillators Battery Charger (voltage doubler) Bi-Coloured LED Bike Turning Signal Bi-Polar LED Driver Bi-Stable 555 Building the Circuits Burglar Alarm 4-Zone Capacitor Charge Pump Car Lights Flasher – warning flasher Car Tachometer Charge Pump Clark Zapper Clicks Uneven Calculator 555 7555 CMOS 555 Constant Current Continuity Tester Crossing Lights Curtain Closer Dark Detector Delay – also called a Timer Delay before turn-on Dog-Bark Stopper Doorbell for front door and back door Dice Dice to 7-Segment Display Display – Animated Divide by 2 Driving A Bi-Coloured LED Driving A Relay Driving White LEDs Duty Cycle 1:1 (50%) Fade-IN Fade-OUT LEDs Fading LED Fastest 555 Oscillator Flasher Flashing Indicators Flashing Railroad Lights Flip Flop see also Toggle Four Alarm Sounds Frequency Divider Frequency Meter Function of each 555 pin H-Bridge H-Bridge Push-Pull – high current H-Bridge with PWM Headlight Flasher – faulty circuit Headlight Selector Hee Haw Siren Higher Sinking Current High Frequency 555 Oscillator How to use the 555 Hysteresis Improving the output of a 555 Increasing Sinking Current Increasing Output Push-Pull Current Inverter 12v to 240v Inside the 555 Jammer for TV Kitt Scanner Knight Rider Laser Ray Sound Latch Latch A Relay Latch – using transistors LED Dice LED Dimmer LED FX Light Controlled Screamer Siren Light Detector Lights – Traffic Lights LMC555 CMOS 555 Low Current Timer – 7555 CMOS 555 Low Frequency 555 Oscillator Low Power 555 Machine Gun Mark-Space Ratio Memory Cell see also Toggle Flip Flop Mercury Switch Detector – faulty circuit Metal Detector Missing Audio Detector Missing Pulse Detector – faulty circuit Model Railway Time Monostable 555 Morse Keyer Mosquito Repeller Motor Controller (stepper Motor) Motor Controller (servo motor) Motor PWM Multivibrator – Astable Music Box Negative Voltage | Normally Closed Trigger One-Shot 555 Organ Phase Control with XR-L555 (low power) Police Lights 1,2,3 Police Siren Powering A Project Pulse Extender Pulser – 74c14 Push Pull Push-Pull – high current PWM Controller – FET buffer PWM – transistor buffer see also Motor PWM Railroad Lights (flashing) Railway Time Rain Alarm Ramp Generator Reaction Timer Game Replacing 556 with two 555’s Replacing TTL 555 with CMOS 555 Resistor Colour Codes Re-triggerable 555 Reversing A Motor Roulette Schmitt Trigger Screamer Siren – Light Controlled Servo Controller Servo Tester Simplest 555 Oscillator Sinewave Output Siren 100dB Solar Tracker – not suitable for 555 Square Wave Oscillator Stepper Motor Controller Stun Gun Substituting a 555 – Part 1 Substituting a 555 – Part 2 Supply (170v) for Nixie Tubes Switch Debounce Tachometer TE555-1 Stepper Motor Controller TE555-2 Animated Display TE555-3 4 Alarm Sounds TE555-4 Dice TE555-5 LED Fx Ticking Bomb Tilt Switch Timer – 5 seconds Toggle A Relay Toggle 555 555 ON/OFF Flip Flop Touch Switch Touch ON-OFF Toy Organ Traffic Lights Traffic Lights – 4 way Transistor Tester Trigger Timer – 74c14 Turning Signal TV Remote Control Jammer Useless Machine Uneven Clicks Up/Down Fading LED Using the 555 VCO (Voltage Controlled Oscillator) Voltage Doubler see also Battery Charger Voltage Tripler Voltage Inverter Voltage Multiplier x10times Warning Flasher – car lights flasher Water Level Detector Wailing Siren Zapper (Dr Clark) Zapper – Voltage Multiplier Zener Diode Tester 2 Minute Timer – 74c14 3x3x3 Cube 4 Alarm Sounds 4 way Traffic Lights 4-Zone Burglar Alarm 1-10 Minute Auto Turn Off 5 Seconds Delay 10 Minute Timer – 74c14 12v DC to 12v DC Battery Charger 12v DC to 19v DC 12v to 240v Inverter 50% Duty Cycle 100dB Siren 170v Supply for Nixie Tubes 555’s – a list of substitutes 555 Amplifier 555 CMOS version LMC555 555 Kit of Components 555 Pinout 555 Pins – Remembering the pins 555 Mistakes (No-No’s) 555 on 24v 555 Timer Calculator 555 VCO 556 Dual Timer 7555 CMOS Calculator 7555 Low Current Timer (delay) |
Kaynak: talkingelectronics.com/projects/50%20-%20555%20Circuits/50%20-%20555%20Circuits.html
555-zamanlayici-entegresi-ile-50-adet-basit-devre
Yayım tarihi: 2010/03/16 Etiketler: 555 circuits, 555 devreleri, 555 timer circuits, basit devreler, circuits book, elektronik devreler, entegre devreler, simple circuits
Kardeşim,eline emeğine sağlık.
Güzel paylaşımlara devam ediyorsun her zamanki gibi.
En ufak bir sorun sıkıntıda yanındayız her zaman.
