PIC16F84 UGN3503 LM358 ile 0 80A Amper Metre
0-80A Ammeter Alternatif link
It’s now rare to see an ammeter installed in a car. Instead, virtually all modern (and not so modern) cars have an “idiot” light to indicate battery charging. Normally, this light is off when the engine is running and only comes on if the alternator fails; ie, when no charge is being delivered.
Apart from that, it doesn’t provide any other information during normal driving.
This means that when the light is out, you have no idea how much current is going into the battery or is being pulled out. And even when an ammeter was fitted, it was hardly what you would call a precision instrument. Most only gave a very rough idea of what happening.
However, if you are an enthusiast, you will want to know more about battery charge and discharge rates. This Automotive Ammeter can provide this information with a high degree of accuracy.
Includes 7-LED bargraph display plus 2-digit readout
±0-30A indication on bargraph in 5A steps
1A resolution on 2-digit display
Typical 80A maximum reading
Dual indication for charge and discharge
Automatic display dimming in low light conditions
13/08/2008 12:27 pm
Bu tür bir devreden acaba benzin deposundaki benzin miktarınıda ölcebilirmiyiz..
19/08/2008 8:00 pm
Bunun Türkçe anlatımı yok mu ?
27/08/2008 2:57 pm
kades türce anlatımı yokmuydu ing. okadar geliştiremedik
