Hi friends, DC motor control I’m doing a study on. As part of this study, a DC motor H-Bridge I need to drive.
Bread on the board, IR2101 an H Bridge consisting of MOSFETs IRFZ44N and I built it. But the mosfet heatsink on the MOSFETs a 3-4 because it is not burned. interruption also on the Board. So I said I’ll make a card. good was in it. 🙂 Or quite a few with the MOSFET I was getting bored. As I said, I used the ir2101 MOSFET driver. Hin and Lin channels can be controlled independently. As a IRFZ44N Mosfet.
IR2101 motor driver circuit diagram
I’ve thought of the system as a 24V supply, but you can 30V. Ir2101 come through the supply of 7812 regulator is provided. This regulator max. be careful not to exceed the input voltage. You can run safely in 24V. I do not come more than 30V feed. I drew the PCB Program Proteus.
IR2101 motor driver PCB
Cooler shoved it from the motherboard of a computer. I’ve used a fan or something because it was on him directly. More precisely, Yi is the PCB made you cooler. There is a space between MOSFETs in the vicinity of 1.5 mm. You may not find the same cooler. It’s not very important. You can connect any coolers that will fit in there.
H-Bridge motor driver project files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25466.zip
http://arectron.com/projelerim/ir2101-mosfet-surucu.html
Publication date: 2016/04/23 Tags: motor control circuit, motor driver circuit, power electronic projects
PCB Ruler Desing
Interesting for those interested in electronics studies, electronics will work in PCB ruler while I’d love to see designs of designs on the card sometimes the setting materials, etc. with these things, the rulers PCB serves.
The first Eagle PCB design program, crafted with double-decker design made of source .have brd you can use to edit the file the way you want to
PCB Ruler
H-Brücke DC-motor-Treiber-Schaltung mit IR2101
Hallo Freunde, DC-motor Steuern, ich mache ein Studium auf. Als Teil dieser Studie, ist ein DC-motor an H-Brücke, die ich fahren muss.
Brot auf dem Brett, IR2101 eine H-Brücke aus MOSFETs (IRFZ44N und ich ihn aufgebaut habe. Aber der mosfet-Kühlkörper auf den MOSFETs eine 3-4, weil es nicht verbrannt wird. Unterbrechung auch auf der platine. Also sagte ich, ich mache eine Karte. gut war es. 🙂 Oder ganz wenige mit dem MOSFET war ich gelangweilt. Wie ich schon sagte, benutzte ich die ir2101 MOSFET-Treiber. Hin-und Lin-Kanäle können unabhängig voneinander gesteuert werden. Als Mosfet IRFZ44N.
Dear Sir
As you mentioned above i want to purchase project can you provide me & How much let me know
Please not that i want to use this as inverter if possible please let me know
It is a DIY (do-it-yourself) project, not for sale. All necessary files for production have been shared.
Good work.
