Elektronik Devreler Projeler » Elektronik Programlar Hesaplama Çevirici Kod vb »
Bobin Hesaplama Programı inductance calculator
Bobin Hesaplama inductance calculator
Bob Stein`in Hazırladığı kurulum gerektirmeyen indiktör ve filtre Hepaplama Programı.Programı Kullanmak için micro2003b.exe dosyasını çalıştırın
INDUCTANCE CALCULATOR
Ver 3.0 7-9-92 This program will calculate the following for round copper wire or copper strap:
1 – Inductance of a single-layer coil
2 – Turns in a single-layer coil for a specified inductance
3 – Turns from coil stock of known pitch (turns per inch or turns per cm) for a specified inductance
4 – Inductance of a straight strap
5 – Length of a straight strap for a specified inductance
6 – Inductance of a transmission-line section
7 – Length of transmission line for a specified inductance
8 – Inductance of a wire parallel to and grounded to a ground plane
9 – Length of wire parallel to ground plane for a specified inductance
10 – Inductance of a straight wire
11 – Length of a straight wire for a specified inductance
12 – Inductance of a multi-layer rectangular coil
13 – Inductance of a multi-layer circular coil
14 – Turns in a multi-layer bobbin-wound coil for a specified inductance
The source code, written in GW-Basic, and the compiled program are not copy- righted and are released into the public domain. No claims are made for its accuracy or suitability for any purpose.
Bob Stein
Dosyalar : bobin_hesaplama_programi.rar
  1. zafer says:
    Bobin Hesaplama Programı linki kırık hocam kontrol edermisiniz selamlar
  2. admin says:
    link yenilendi Teşekkürler
