Sanyo üretimi STK serisi güç amplifikatör entegrelerine ait orjinal devre şemaları şemalar üreticinin (sanyo) olduğu için sorun olacağını sanmam piyasada orjinal STK entegresi bulmak zor olsada kopyaları özgün tasarıma göre yapılıyor genelde güç transistörlerinin kalitesi düşük ama sahtede olsa bir çok anfi entegresinden, transistörlü anfilereden vs. çok daha iyi ses veriyor.
Şema listesi;
- STK060 27Volt 30Watt
- STK0060 40Volt 60Watt
- STK0060II 41Volt 60Watt
- STK0070 43Volt 70Watt
- STK0070II 45Volt 70Watt
- STK075G 20Volt 15Watt
- STK077G 22Volt 20Watt
- STK078 105 25Volt 24Watt
- STK078 25Volt 24Watt
- STK078G 25Volt 24Watt
- STK080 27Volt 30Watt
- STK0080 46Volt 80Watt
- STK080G 27Volt 30Watt
- STK0080II 47Volt 80Watt
- STK082 105 30Volt 35Watt
- STK082 30Volt 35Watt
- STK082G 30Volt 35Watt
- STK083 32Volt 40Watt
- STK084 35Volt 50Watt
- STK084G 35Volt 50Watt
- STK086 42Volt 70Watt
- STK086G 42Volt 70Watt
- STK0100 50Volt 100Watt
- STK0100II 52Volt 100Watt
- STK0105 50Volt 100Watt
- STK433 23Volt 2x5Watt
- STK435 27Volt 2x7Watt
- STK436 32Volt 2x10Watt
- STK058 25Volt 24Watt
- STK0040 33Volt 40Watt
- STK0040II 36Volt 40Watt
- STK0049 35Volt 45Watt
- STK0050 36Volt 50Watt
- STK0050II 39Volt 50Watt
- STK055 20Volt 15Watt
- STK057 22Volt 20Watt
- STK0025 24Volt 23Watt
- STK0028 25Volt 25Watt
- STK0030 28Volt 30Watt
- STK0039 31Volt 35Watt
- STK4102II 13Volt 2x6Watt
- STK4112II 17Volt 2x10Watt
- STK4122II 20Volt 2x25Watt
- STK4131II 23Volt 2x20Watt
- STK4142II 26Volt 2x25Watt
- STK4151II 27Volt 2x30Watt
- STK4162II 30Volt 2x35Watt
- STK4171II 32Volt 2x40Watt
- STK4182II 33Volt 2x45Watt
- STK4191II 35Volt 2x50Watt
- STK4192II 35Volt 2x50Watt
- STK4231 32Volt 2x100Watt
- STK4231II 23Volt 2x20Watt
- STK4301 31Volt 2x22Watt
- STK4311 35Volt 2x28Watt
- STK4332 23Volt 2x5Watt
- STK4352 27Volt 2x7Watt
- STK4362 33Volt 2x10Watt
- STK4372 35Volt 2x12Watt
- STK4048II 59Volt 150Watt
- STK437 33Volt 2x10Watt
- STK439 39Volt 2x15Watt
- STK441 44Volt 2x20Watt
- STK443 49Volt 2x25Watt
- STK457 18Volt 2x10Watt
- STK459 21Volt 2x15Watt
- STK460 23Volt 2x20Watt
- STK461 23Volt 2x20Watt
- STK463 26Volt 2x25Watt
- STK465 28Volt 2x30Watt
- STK1030 28Volt 30Watt
- STK1035 28Volt 30Watt
- STK1039 30Volt 35Watt
- STK1040 33Volt 40Watt
- STK1045 33Volt 40Watt
- STK1050 36Volt 50Watt
- STK1059 38Volt 55Watt
- STK1060 40Volt 60Watt
- STK1070 43Volt 70Watt
- STK3042 36Volt 2x40Watt
- STK4036 35Volt 50Watt
- STK4036X 36Volt 50Watt
- STK4038II 38Volt 60Watt
- STK4038X 39Volt 60Watt
- STK4040II 42Volt 70Watt
- STK4040X 42Volt 70Watt
- STK4042II 45Volt 80Watt
- STK4044II 51Volt 100Watt
- STK4046XI 55Volt 120Watt
- STK4048 55Volt 150Watt
- STK0059 38Volt 55Watt
stkli-anfi-semalari
benmi indiremiyorum yoksa bu linktemi sorun var anlıyamadım. Gev hocam bi el atabilirmisiniz…?
Ustam senden Allah razı olsun işini gücünü bırakıp karşılıksız bizlere güzel bilgiler veriyorsun.bana göre cennetliksiniz ustam bende elektronik ve müzik sistemleri hastalığı var.var ama elektronik bilgimyok elimde üniversal 38 cm.30a0watlık 8 ohm.2 yollu 4 adet kolonum var.pioneer sa 540 müzik amfi setim var 4 kolonu bağlayamıyorum bağladığım zaman ses çıkmıyor .
Elime bir arkadaştan 1000 wat 2×44 volt çıkışlı 1 trafo geçti bu trafoyu değerlendirmek istiyorum .benim düşüncem 2 adet stk 4050 yi kullanarak stryo bir amfi yapmak.ustam bu trafo 2 adet 4050 yi sürermi 2 adet 4050 liyle bu kolonları çalıştırabilirmiyim.ustam esas konuya geleyim olur derseniz .bana 2 tane stk 4050 amfi devresi kısa devre korumalı yapıp ödemeli olarak gönderirmisiniz.ùcreti neyse öderim,amfileri yapacak bilgim yok besleme devresinin şemasını çizseniz yeter onu ben yapabilirim bende kondansatör diot var.ustam telefon numaranızı bana yazarsanız derdimi size daha iyi anlatabilirim. kendinize iyi bakın saygılarımla.
Stk411-220e var elimde bu entegreye ait hiçbir yerde şema bulamadım yardımcı olur musunuz?
Linktemi sorun var yoksa cahilligimizdenmi becerip indiremiyoruz
Linkte sorun yok. Öncelikle ilk indirdiğiniz zip li dosyadan dosyaların bulunduğu sunucuların doğrudan indirme linklerini alıyorsunuz. Bir tanesini seçip indiriyorsunuz. Daha sonra indirdiğiniz rar lı dosyayı şifresiyle açıyorsunuz.
merhabalar..stk 463 çıkışımda tizlerde distortion problemi var. Bunun nedeni orjinal çıkışı kullanmadığımdan mıdır?
Kusura bakmayın bir sorum olacaktı Resimdeki müzik setinin ses çıkışlarından ses alamıyorum. Stk 437 yazan entegreyi değiştirmem yeterli mi
https://ibb.co/j6Hdw7x
https://ibb.co/wpxmXp8
Merhaba
Bu soruya doğru cevap vermek çok zor.
Belki sigorta atıktır, besleme voltajı yoktur, koruma devresi çıkışı engelliyordur.
Belki de stk bozulmuştur.
Deneyebilirsiniz, stk amfi üretimini Sanyo bıraktıktan sonra piyasada çakma (klon) ürün arttı. Eskisini dikkatlice, zarar vermeden sökün. Yenisini taktığınız çalışmaz ise eskiyi atmayın.
Arızayı bulduğunuzda ses hoşunuza gitmezse tekrar eskisini takarsınız.
Kolay gelsin.
