Bir çok gps projesi bulunmakta ayrıca gsm dtmf ve bir çok uygulama özellikle optik maus ile lcd göstergeli ölçüm devresi hoş tüm projeler tek sayfada verilmiş kaynak asm kodları var bazılarında pcb (PCBE Version 0.42.1) dosysı da bulunmakta ve pc ile haberleşeme kontrol programı olan devrelerde kaynak Visual Basic kodları da verilmiş
Sayfa çok uzun olduğu için google translate bir kısmını ingilizce çeviriyor gerisini Text çeviri yapmak zorundasınız
Örnek resimler
GPS-52-Gemini changed
Track length instruments area
Assembler ASM30 dsPIC real function
Basic dsPIC (his students)
ASM30 dsPIC real function for routine operations
Equipment-oriented absolute orientation
The application of optical mouse kit
Voice-band system FFT
GPS-4 how to map a path drawn
PIC voice band production system using the FFT
GPS Gemini from the CCA, the PIC CPU control
Robot vehicles that operate
Issue of voice identification 18F452
Voice identification – or vowel, and arm
remote control and data acquisition system using two mobile phones
Remote control and data acquisition system using the telephone
Two. Three-dimensional laser scanner
GPS-4 for a computer to process data number of Visual Basic
About half own GPS is published
G-LCD (SG12232) drive generic PIC assembler program
PIC18F252 was introduced using their own calculator
PIC18F252 G-LCD does not include the font
GPS is about half his own previously reported PIC18F252
PIC real functions and operations
LPS (local measurement system) graphic LCD display GLCD
PIC to EEPROM for data storage devices
PIC18F252 real function in the operation, MPASM assembler
DTMF signals remote control
GPS system is already reported PİC16F876
10-bit AD converter, PIC17C756
PIC16F876 own half with a GPS system
PIC inverted pendulum using a fully independent
PIC16F84 applying a key lock system
HID (human interface device) Usually the left of the photo of the mouse
RS-232C connection. PIC16F873 2-axis acceleration sensor (ADXL-202)
PIC using tried to make a remote measurement system.
Kaynak Web Sitesi Results obtained in the laboratory
Tüm GPS projeleri için alternatif;
Yayım tarihi: 2009/01/25 Etiketler: dspic, dtmf, GLCD, gps devreleri, gps projeleri, microchip pic projeleri, PIC16F873, PIC16F876 örnekleri, pic17c756, pic18f252, Visual Basic
Çok teşekkur ederim.Gerçekten çok lazım olan bilgilere ulaşmamı sağladı.
teşekkürler
link ölmüş acilen linki yenilermisiniz bu konu çok önemli
link yenilendi
iyi çalışmalar
çok teşekkürler 😀
