Güç elektroniği konusunda işinize yarayacak bir çok formul, hesaplama bulunuyor ingilizce bir kaynak fakat çözmesi kolay olacaktır.
10 Cornerstones | dc-dc converters | Kirchoff’s current law | root mean square |
1-phase bipolar inverter | decibel | Kirchoff’s voltage law | rpm |
3-phase inverter | delta-wye transformer | KVL | induction motor |
3-phase power and | dependent variable | L inductance | s slip |
commutation | derivatives | L’Hôpitol’s rule | SS capacitor principle |
3-phase PWM inverter | diode current | LC tank circuit | SS inductor principle |
3-phase rectifier | distortion | linear range | series |
3-phase Thèvenin equivalent | duty cycle | linearizing an equation | single-phase bridge rectifier |
E electric field | ma amplitude modulation | slip | |
with a | efficiency of induction motor | ratio | slip frequency |
3-phase voltage and | magnitude | slip speed | |
commutation | electric motors | Maxwell’s equations | space-time |
air gap flux | Euler’s equation | mf frequency modulation | sphere |
amp | even function | ratio | square wave |
Ampere’s law | farad | minimum inductance | Fourier series |
amplitude modulation ratio | Faraday’s law | model | square wave inverter |
area | Fourier series | induction motor | starting torque |
sphere | square wave | motor | step-down converter |
average | frequency domain | induction motor | step-up converter |
average value | frequency modulation ratio | newton | synchronous pulse width |
B magnetic flux dens | fsl slip frequency | ns synchronous speed | modulation |
binomial expansion | full bridge converter | odd function | synchronous speed |
binomial theorem | Gauss’ law | overmodulation | tank circuit |
bipolar inverter | general math | parallel resistance | temperature |
bridge rectifier | generalized harmonics | PF power factor | tesla |
buck converter | 1-phase | 3-phase rectifier | THD |
buck-boost converter | 3-phase | phase | Thèvenin equivalent |
C capacitance | graph paper | phase current | 3-phase |
calculus | graphing terminology | phasor notation | with a |
capacitance | H magnetic field | plotting I1 | three-phase rectifier |
capacitor | half-wave rectifier | plotting iA | time domain |
CF crest factor | harmonics | plotting paper | time-average |
commutation | generalized, 1-phase | plotting V1 | time-averaged power |
3-phase power | generalized, 3-phase | plotting Vdc | time-harmonic |
3-phase voltage | henry | power | torque |
power | Hoft | electric motor | constant |
voltage | horsepower | power and commutation | starting |
commutation interva | hyperbolic functions | power factor | trigonometric identities |
complex conjugate | I1 | 3-phase rectifier | u commutation interval |
complex numbers | iA rectifier current | pull out | unibipolar inverter |
conjugate | independent variable | pulse width modulation | units |
complex | inductance | synchronous | V1 |
constant torque | induction motor | pulse width modulation in | Vdc |
constant volts/Hz | induction motor model | inverters | vi relationship |
converter | inductor | PWM pulse width | volt |
buck10 | LC tank circuit | modulation | voltage and commutation |
buck-boost | integration | PWM inverter | volts/Hz ratio |
Cúk | inverter | 3-phase | volume |
dc-dc | 3-phase | rectifier | sphere |
step-down | bipolar | three-phase | watt |
step-up | harmonic voltage | rectifiers | weber |
coulomb | pulse width modulation | resistance | wye-delta transformer |
crest factor Cúk converter D electric flux dens | J current density joule KCL | in parallel resistor2 rms | fag air gap flux h efficiency of induction motor |
dB decibels dc dc-ac inverters | kelvin Kimbark’s equations with a | square wave rms harmonic voltage in inverters | rn volume charge dens wsl |
yukarı da içerik listesi verildi kaynak;
guc-elektronigi-hesaplamalar-formuller
Yayım tarihi: 2010/02/22 Etiketler: dc hesap, güç formül, güç hesap, smps hesap
çok güzel bir belge. teşekkürler. yüzsüzlük olacak ama varsa diğer alanlara ait (haberleşme, elektromanyetik vb…) formül kartlarını da bekleriz 🙂
