TDA73XX Serisi ile 4x Oto Anfi Devreleri
TDA7385 TDA7386 TDA7360 TDA7384 TDA7383 TDA7381 4x Oto Anfi devreleri
TDA7385 TDA7386 TDA7360 için PCB Çift yüzeyli pcb 3 entegre için kullanılabiliyor denemedim
entegre datasheet dosyalarından bacak bağlantılarını kontrol edin
Powerful new UNCH of Hi-Fi MASTER KIT
Power amplifier for TDA7386 TDA7385, TDA7384, TDA7383, TDA7381 Tek yüzeyli pcb
TDA7560 4×45w quad bridge car radio amplifier plus hsd
superior output power capability:
4 x 50w/4? max.
4 x 45w/4? eiaj
4 x 30w/4? @ 14.4v, 1khz, 10%
4 x 80w/2? max.
4 x 77w/2? eiaj
4 x 55w/2? @ 14.4v, 1khz, 10%
multipower bcd technology
mosfet output power stage
excellent 2? driving capability
hi-fi class distortion
low output noise
st-by function
mute function
automute at min. supply voltage
detection
low external component count:
internally fixed gain (26db)
no external compensation
no bootstrap capacitors
on board 0.35a high side driver
1.1 protections:
output short circuit to gnd, to vs,
across the load
very inductive loads
overrating chip temperature with
soft thermal limiter
output dc offset detection
load dump voltage
fortuitous open gnd
reversed battery
esd
TDA7386
4 x 45w/4w max.
4 x 40w/4w eiaj
4 x 28w/4w @ 14.4v, 1khz, 10%
4 x 24w/4w @ 13.2v, 1khz, 10%
TDA7385
4 x 35w/4w max.
4 x 30w/4w eiaj
4 x 22w/4w @ 14.4v, 1khz, 10%
4 x 18.5w/4w @ 13.2v, 1khz, 10%
TDA7384
4 x 40W/4W MAX.
4 x 35W/4W EIAJ
4 x 25W/4W @14.4V, 1KHz, 10%
4 x 22W/4W @13.2V, 1KHz, 10%
TDA7383
4 x 35W/4W MAX.
4 x 30W/4W EIAJ
4 x 22W/4W @ 14.4V, 1KHz, 10%
4 x 18.5W/4W @ 13.2V, 1KHz, 10%
TDA7381
4 x 30W/4W MAX.
4 x 25W/4W EIAJ
4 x 18W/4W @14.4V, 1KHz, 10%
4 x 15W/4W @13.2V, 1KHz, 10%
1/07/2008 3:32 pm
giriş gerilimleri kac volt vcc 3-4 volt yazmıssın
11/09/2008 3:44 am
hola soy de argentina y quisiera saber si me podes mandar por mail el pcb de la plaqueta del integrado tda7384 ya que lo baje pero NO LO PUEDO ABRIR si no es mucha molestia te agradecerÃa que fuera en blanco y negro ya qye de otra forma no lo puedo imprimir para luego pasarlo a la plaqueta desde ya GRACIAS
15/11/2008 11:00 pm
12 volt olması lazım
