The console lights
* 8 outputs for filament lamps on which you can adjust the brightness and set 3 different types of effects: psychedelic, sequential blinking or their mixing;
* 4 outputs ON-OFF from which you can take the power for any type of user: strobe lights, wood lamps, motors to move spotlights, mirrors, and so on.
On the console panel are available the following commands:
* 8 potentiometers to adjust the brightness of each lamp
* 8 diverters three positions to shut down, turn on or enable the effects on each lamp
* 2 LEDs that indicate the status of 12 outputs (8 lights + 4 on-off)
* 4 switches for controlling expenditure on-off
* Switch, led potentiometer and speed relative to the sequential
* Switch, led potentiometer and speed relative to the flash (flash)
* Switch, led, potentiometer level and microphone (internal or external) relating to the psychedelic
* Button dark temporary (all lights off)
Light Game
This unit generates light effects (both On-Off that fade) on 8 filament bulbs connected to the corresponding channels.
There are lighting effects for 4 lamps (4 +4, channels 5 … 8 are the repetition of 1… 4) and 8 lamps.
Programmable Lighting Effects
The draft presented in this document is a generator of programmable lighting effects and relay outputs can be used to illuminate cribs, scenes, illuminated signs, etc., or more simply to turn so programmed the various users connected to the outputs.
The programming (ie lighting effects, the evolution of the relay and timing of implementation) is done by connecting the circuit to the serial port of a PC (personal computer) and using the accompanying software that allows you to view and edit the various developments in operation time. Of this project are available: the schematic, drawings, printed circuit board, all sources (both firmware resident on the cpu that used for programming the computer) and various documents and diagrams flow (flow-charts) .
