PIC16F628A Örnek RF Alıcı Verici Devresi C Dili ile
“PIC16F628A Örnek RF Alıcı Verici Devresi C Dili ile” Projenin Kaynak proteus isis simülasyon ve alıcı, verici yazılım dosyaları var. Emeği geçen Kişilere Teşekkürler RF Alıcı Verici Devre Şeması
Alıcı.c
#include <16F628.h>
#FUSES NOWDT,NOPUT,PROTECT,BROWNOUT,NOMCLR,NOLVP,INTRC_IO
#use delay(clock=4000000)
#use rs232(baud=300,parity=N,rcv  = PIN_B1, XMIT = PIN_B2, bits=8,  ERRORS,BRGH1OK )
#Byte    PORTA       = 5
#Byte    PORTB       = 6
#Bit     C_ac        = PortA.0
#Bit     C_kapa      = PortA.1
#Bit     G_guvenlik  = PortB.3
#Bit     G_Acik      = PortB.4
#Bit     G_kapali    = PortB.5
void     ilk();
int8    x=0,y=0,Vtam=0,Basla=0;
int8     dat[4];
#int_RDA
void serial_isr() {
if (Kbhit()) y=getc();
if ((y=='B')&&(!vtam)) Basla=1;
if (Basla)
   {Dat[x]=y;x++;
         if (x > 2){
            if (Dat[1] == 'C'){vtam=1;basla=0;x=0;}else
               {Vtam=0;basla=0;x=0;}
void main()
   ilk();
   while(1){
   if (Vtam){
      Disable_interrupts(GLOBAL);
      if (Dat[2]=='A') // Aç Komutu
      if (G_kapali==0 && G_guvenlik==1)
      C_ac = 1;
      while (C_ac == 1){
         if (G_acik==0) C_ac = 0;
         if (G_guvenlik==0) C_ac = 0;
      if (Dat[2]=='K') // Kapat Komutu
      if (G_acik==0 && G_guvenlik==1)
      C_kapa = 1;
      while (C_kapa== 1){
      if (G_kapali==0 || G_guvenlik==0)
      C_kapa = 0;
   vtam     = 0;
   enable_interrupts(GLOBAL);
void ilk(){
   Set_tris_B(0B00111010);
   Set_Tris_A(0);
   clear_interrupt(INT_RDA);
   clear_interrupt(INT_EXT);
   PortA = 0;
   PORTB = 0;
   port_b_pullups(TRUE);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);
   setup_vref(FALSE);
   setup_uart(True);
   enable_interrupts(INT_RDA);
Verici.c
#include <16F628.h>
#FUSES NOWDT,NOPUT,NOPROTECT,BROWNOUT,NOMCLR,NOLVP,INTRC_IO
#use rs232(baud=300,parity=N,rcv  = PIN_B1, XMIT = PIN_B2, bits=8, ERRORS, BRGH1OK )
#Byte    PORTA    = 5
#Byte    PORTB    = 6
#Bit     B_ac     = PortB.4
#Bit     B_kapat  = PortB.5
void     ilk();
void main()
   ilk();
   while(1){
   if (B_ac==0) {
   Putc('B');Putc('C');Putc('A');
   Delay_ms(100);
   Delay_ms(100);
   Delay_ms(100);
   if (B_kapat==0){
    Putc('B');Putc('C');Putc('K');
   Delay_ms(100);
   Delay_ms(100);
   Delay_ms(100);
void ilk(){
   Set_tris_B(0B00110010);
   Set_Tris_A(0B00000000);
   PortA = 0;
   PORTB = 0b11110010;
   setup_vref(FALSE);
   setup_uart(True);
3 Yorum
  1. H
    hüseyin
    hocam alıcı verici devrelerinde bir filtre kullanmak mecburi mi? yani veriyi 5-6 defa peşpeşe yollasak bu yetersiz mi kalır acaba?
    birde band-pass filter ı devreye nasıl bağlayacağız? anlayamadım onu bir türlü.
  2. A
    aslıhan
    isis simulasyon dosyası hangisi?
      rf_F628.DSN
