Elektronik Devreler Projeler » Elektronik Programlar Hesaplama Çevirici Kod vb »
C Dili Bilgisayar ile Elektronik Devre Kontrolü Lpt Com
c-dili-elektronik-devre-kontrolu-programlar
C dili ile ilgilenen işin içine elektroniğide katmak isteyen kişiler için kaynak olabilir feyz alabilirler projelerin çoğunda programların kaynak C/C++ Kodları bulunmakta ayrıca exe halleride var bazı devrelerin animasyonları çalışma sistemlerinin anlaşılmasında çok yardımcı olur bu tip animasyonları hazırlamayı öğrenebilirim umarım :) devreler arasında telefon arama ID numaralarını kayıt eden program çok ilginç CM8870 çalışmasıda görsel olarak iyi anlaşılıyor ;)
Serial communication with door
serial-communication-with-door
The article is still being produced, but below the software can now be copied via download. O Software atual é Freeware (uso livre). The current software is Freeware (free use).The program below is ideal to test the communication between two computers, circuits with microcontrollers, devices in general that uses the Serial communication. few commands to test the modem with this software, for it is only in select your modem port which is installed (COM1, COM2 …)
Control of Motor the parallel port
control-engine-step-using-uln2003
Motor steps are of electro-magnetic mechanical devices that can be controlled digitally through a specific hardware or through software.MOTOR steps to be found in devices where precision is a very important factor.They are widely used in printers, plotters, scanners, drivers, floppy disks, hard disks and many other appliances.
Electronic devices controlled via internet
electronic-devices-controlled-via-internet
The objective of the project drawn up here, is to control and monitor electronic devices remotely via the Internet, and easily understandable by those who love the world of Telematics, Teleprocessamento, Electronics, Programming, finally, to all those who arouse curiosity in the matter. The project has no kind of security against undue control or access by outside users.This project may mature later, using login and password, but also protection via Firewell. Can be controlled (on / off) until 8 electronic devices, sensors and tracked by 5 at least every 1 second, and at most 10 seconds. It takes at least three computers connected to the Internet so that we can establish the control and monitoring devices / sensors
Monitor 32 Sensors Simultaneously over the parallel port
monitor32-sensors-simultaneously-parallel-port
Now, we can simultaneously monitor 32 devices and the “right time” reads 32 sensors connected to the parallel port through this project. Who works with the parallel port knows that it has only 12 outlets: (8 in the registry database and 4 in the Registry of control), thus enabling the control of only 12 devices simultaneously.The project developed in this article uses only 3 pins the parallel port to control the 32 devices connected to the interface circuit, composed simply of 4 ICs Shift Register 74LS164N and 4 Latchs 74HCT573 and some auxiliary components. I read the 32 circuit that uses sensors 7 Pin the parallel port. Still, are available 6 exits and 1 parallel port of entry to do what you want with them.
Connectivity 8 key Serial port VIA microcontroller Access Control
connectivity-8key-serialport-via-microcontroller-accesscontrol
The program recorded on the PIC was written in C language and has over 1,000 lines of source code. In this article is available free for download, code Hex record for the PIC 16F877 and manage up to a maximum of 2 keyboards, ideal for beginning to develop and master the technology. Up to two keyboards, provide the PIC already written, ready to be added to the hardware available in this article. You are not limited to only one operating system to develop applications for controlling access to that hardware. It may develop into Linux and other operating systems.
8 step motors connected to the parallel port
8step-motors-parallel-port
The circuit interfacing with the parallel port is the same Article DSP32es, except that instead of the 32 outlets will use LEDs in 4 drivers ULN2803 to control the 8-step motors. The whole logic of control will be the responsibility of the software. The secret Software is the proper manipulation of bits, and to understand their operation, it is important to remember the concepts of bits, Nibbles, bytes, binary operators AND, OR e de deslocamento. AB and displacement.
The caller ID for sings DTMF
integrated-circuit-cm8870-operation
C om the use of the CM8870 and some other auxiliary components you can create a remote-control device via telephone or radio network. Through a phone or a cell phone, a kilometer away from our residence, we can turn on / off a lamp or any other device that is connected to the controller circuit. circuit is connected to the parallel port, and all the processing, scheduling and organization of data recognized by the CM8870 is done by the LPT ID program The interface to the parallel port for data entry recognized, was fully photo-coupled with the use of high-speed MOC5009. The photo-coupling was necessary to eliminate the noise generated by the computer to the phone line, and at the same time protect the same high-tension.
dtmf-lpt-id-save
Projelerin tümüne Buradan ulaşabilirsiniz sadece bedava olan uygulamaları tanıttım kaynak sitede kısıtlı olan programlarda var alternatif link: c-dili-bilgisayar-ile-elektronik-devre-kontrolu-lpt-com.rar alternatif link2
  1. saim says:
    sizi tebrik ediyorum benim gibi elektrik müh. buna aşırı ihtiyacı vardı.
