Atmel Avr Proje Devre Arşivi 360MB
Yıllardır internet ortamında bir çok siteden topladığım çeşitli atmel avr projeleri alışkanlık işte bir gün işe yarar düşüncesi ile arşiv baya bir büyümüş. Atmel ile ilgilenen kişiler için sağlam bir kaynak olacağı kesin.
Atmel AVR Proje Devre Arşivi; Part-1: atmel-archive.part1 Part-2: atmel-archive.part2
# Generated on by Directory Lister v0.7.2
0000-9999
2 line X 16 char LCD display
20pin atmel mikroişlemcili kayan yazı
2ch_temp_sensor
4 canal 232
4-Farben LED
5×7 LED dot matrix pong
8_way_nalyzer_with_90S1200
8051 CDROM PLAYER-AL
8051 In Citcuit Real Time EmulatorProgrammer
8051 Keypad ile saat uygulaması
8051SBC V1.0
A HiFi Power Amp ATMEL
A Little More Serious Frequency Meter
A Low Power PLL FM Transmitter
A small robot board with the AVR
Acceleration meter cars
Accelerometer
Ad TLC2543 with_spi
ADC_with_digit_8_led_
Akbil
Alarmclock
An ATmega8 based UI TNC
Analog to Digital capabilities of Atmel ATtiny26
AntiKippenLights-Mini
AT 90s8515 AVR evaluation board
AT89C1051 AT89C2051 AT89C51
AT89C2051 PCB
AT89C2051 Programmiergerät als ISA-Steckkarte
AT89C2051 PULSE METER
AT89C2051 timer
AT89C2051
at89c2051-24pı led show pc destekli
AT89C4051 as RTC V1.1
at89c51 cdromplayer
AT89C51-based 8051 in-circuit-debugger
ATAATAPI CDROM application using a 8051 based Micro controller
ATmega128 Resources
atmel 89s8252 kayan yazı devresi
Atmel AT89C2051 microprocessor – a 20 pin 8051 variant, with FLASH (reprogrammabl
ATMEL ilevoltmetre
atmel ısık
atmel rs232
atmel Unipolar Stepper Motor
atmel vu mette
Audio Spectrum Monitor
Automator is a hardware device which controls relays
AVR – CDC
AVR boards commonly
AVR Chatboard
AVR DDS signal generator V1.0
AVR Dragon
AVR ICSP Adapter Par
avr ısp
AVR Ohjelmointilaite
AVR RS232 interface
avr saat
AVR Thermometer
avr vertical color genarator
avr_clock
AVR_ICSP
avr450_charger
AVR-8QUEEN
AVR-Based Microstepping Bipolar Chopper Stepper Motor Driver
AVR-Based Serial Port IR Receiver
AVR-Einchip-Prozessoren
AVR-Kreis
AVR-Projects
Bar Code Reader
Based Digital Lock-In Milliohmmeter
Basically the AccelR8
Bench Power Supply 0-25v 0-4 Amp
Bluetooth boards developed within the CSE
C-52EVB Robot Controller
Cheap DSP Experiments
Circuit and firmware to support Seiko-Epson
Clock Controller V1.1
Control AVR microcontrollers via Visual Basic
control_large_power_led
CONTROLLER for HYBRID
Countermeasures
DAC-GC01
DAC-V2
Das Hochspannungsgerät
Das Nickel – Cadmium Schnellladegerät
DASICARPODOC means DAve’s SImple CAR iPOd DOCk
DC MOTOR
DC Servomotor Controller
DC-DC
DCF Nixie Clock
DCIBUS
DCIETH an Embedded Ethernet Controller
DDS Function Generator
De ATMEGA-PLC
Der Scroller
Desktop Line Following Robot
Die Diesel-Ente
Digital Capacitance Meter
Digital Clock with Alarm Using DS1307
Digital Guitar Tuner
Digital Intercom
Digital RF Field Strength Indicator
Digital TemperatureHumidityBarometric pressure
digital_thermostat_with_high_accuracy
Distributed fun — Mark II
Door Bell
DRAM (Simm Modul) am Atmega8
DS1302+AT89C2051
DS1820 Temperature Sensor High-resolution Readout Dem
dspio board
DTMF
DTMF-
DTMF_decoder
DTMF_dialer_with_bascom-avr
Dynamischer MIDI Infrarot-Sensor
e10-g rs232 modem
Electronics — 10xHz Precision Clock Generator
EPROM Emulator Mk2
Evertool is an AVRISPSTK500-protocol and
Experiment 8051SBC with C51 compiler
Experimental 1 KHz Synchronous Detector
Fréquencemètre à base de AT89C2051
Frequency Generator
Frequency Meter
FT232 Testboard
GPS-Simulator
Graphic LCD Library for SED1330
Graphic Lcd on USB
GSM-RUFALARM
HAMEG-Interface
Hardware emulator Czechoslovak microcomputer (RETROARCADE simulator)
hdd hava yazı
Home Automation Over Internet
Home Built Laser Projector
Implementation USB into microcontrollerIgor Atmel-USB device
InterBoard-ATmega8BK,ATmega8LBK
Interface 4 role
IO-Board für µC mit AVR ATmega8
key matrix & sound
Konwerter klawiatura PC — RS232
large_lcd_usb2_mp3
LC Determination byResonant Frequency Measurement
LCD5210 3310USB
lcd counter
lcd keys
lcdterm
LED Clock R5
Led Sign with MMC Memory Card
LED-Laufschriftanzeige
Liion_charger_for_roboty
Line Follower ROBOT
Logik-Logger
Low Cost Telemetry Device- LTD
Lux Meter
M48
M8+LCD1602+LM35 srj
MAX038-Based SweepFunction Generator With Markers
midi genarator
Milliwattmètre
Mini DDS direct dijital synthesis
mini WEB Server mit Atmel-Mega Controller und CS8900A
Miniature Real-time Controller
MiniLOGGER v1
MiniLogger V3.0
Minimum Mass Waveform Capture and Display
Minimum Mass Wireless Coupler Terminal Interface
Minimum Mass Wireless LCD Display
MMC to Serial Adapter
Model Tren Digital Control (DCC)
Modelo ATMEL
Monster Memory
Motion Tracking
MP3 mega162
MP3 Player
mp3_using_asm_and_atmega8
mp3_using_c_and_atmega8
multi-function PIC16F84A-based project board
mutil_meters_with_m128
My first attempt with RF modules
myAVR
Network Light Dimmer with Slider Control
New 89C52 Microprocessor learning board with external 32kB eeprom
Night Light Saver V6
Nokia 6100 Display am AVR
Nokia LCD Library
NTSC Test Signal Generator
numitron_clock
OBD II LCD für µC mit AVR ATmega ohne separaten OBD Controller-Chip
One_handed_keyboard
Oxygen MP3
Pocket-Sized MP3 player
Port-Powered Temperature Meter
PowerSwitch
PROFLASH Board (Amtel MCS-51 & AVR)
projects
Propeller AnalogDigital Clock
pulse metter
PWM 4 Kanal
PWM_SCHALTNETZTEIL
pwm_servo
Radio Spectrum Monitor
rc_speedcontroller_atmel
Rcen FUSE BİT PROGRAMMER
RCEN-Blower
Rechners mit AT Mainboard
remode
remote_your_pc_with_bascom
RS-232 Freq. MeterPulse Generator
RS-232 to 100 MHz RF desktop channel adapter
S-52 Simple Learning Board
Sat AT89C2051 havada yazı led
Schaltmodul mit ATMEL ATTINY2313
ScopeClock mit D7-16 und Atmel-Controller
Serieller Datenlogger mit 512k Speicher
servo
simple_ir_alert
simpleVGA video adapter
Skyboat
SMS remote control with 4 relays version
Solar Energy Meter
standard_usb_interface_using_FT232AM
Stepper Motor Driver RS232
SuperhetDirect Conversion AM receiver
tarih sıcaklık
Teichpumpen-Steuergerät
telecard reader
Temperature Controller
TempGrid – Viele DS18S20 an einem AVR uC
Text LCD Library for HD44780
TEXTSIM
Thermistor Thermometer LCD version
Timer mit ATmega8
Timer
timer_avr1
Train Modeling Digital Devices Control (DCC)
uC starterkits
uCOS-II AVR-GCC port
UNITALK
Universal Counter
USB & GLCD expansion board for 8051SBC
USB Flash memory writer
USB Host Control for HID Devices By AVR Microcomputer
usb interface usb ınfred remote contrl
USB servo controller
usb swic
USBasp – USB programmer for Atmel AVR controllers
USB-LCD-Module und Converter
USB-LED-Fader
using_pc_rs232_to_ctronl_avr_led
VAG CD Changer Simulator
Video Line Selector
video_and_sound_generator
Warmwasser
Wavetable Melody Generator
Weather Station
Wetter-Logger (Temperatur, relative Luftfeuchtigkeit, Luftdruck)
wind_meter
Wireless Coupled Frequency Meter
xTimer V1.0
xTimer with 4094
atmel-archiveatmel_Easy-Downloader
1
Easy-Downloader V1.1 for ATMEL 89C20514051
Easy-Downloader V1.1 with SDCC
Easy-Downloader V2.0 for ATMEL 89C515255 89S5152
Easy-Downloader V2.1 for 89C5189C5289C55WD
Easy-Downloader V3.0 for 89C51-89C52-89C55WD
How Easy-Downloader V2.0 Connects Host PC
Make Your Own Single-Side PCB for Easy-Downloader V1.1
Make Your Own Single-Side PCB for Easy-Downloader V2.0
Program the AT89S8252 and 89S53 with Easy-Downloader V2.0
Using Easy-Downloader V1.1&V2.0 with Unsorted HEX Files
Very Easy Single Side PCB for easy downloader v2.2
Very Easy Single-Side PCB for Easy-Downloader V1.1
atmel-archiveatmel_PROGRAMMERS TEST BOARD
8051 Development Tools
8051 test board
89251P~1PROGRAMER
89C2051PROTO BOARD
89S52 Project Board
AT89C2051 Testboard
AT90 DEV BOARD
Atmel 89 Series Device Programmer
ATMEL 89 Series Flash Microcontroller Programmer Ver 3.1
Atmel 89c2051 programaer
ATMEL 89Cx051 PROGRAMMER
ATMEL 89xxxx PROGRAMMER
Atmel AT89C2051 programmer
Atmel AT90S1200 programlayıcı (Paralel port)
ATMEL AVR PROGRAMMER
Atmel Isp Programmer At89Isp Original Cable Schematics And Software
atmel programlayıcı kit 123
Atmel-USB-Programer
AVR AT90S2313 Development Board
AVR ATmega8 Testboard
C-52 Evaluation Board
Carte de développement modulaire pour AVR
Flash-EPROM-Programmiergerät
Holgi’s AVRATMega Prommer und Testboards
IsoJtagISP AVR Programmer
ISP Flash Microcontroller Programmer
Ponyprog Circuit for ATMEL’S AVR
Programator ATMEL mikrokontrolera
programátor obvodu AT89C1051, AT89C2051, AT89C51, AT89C52 a AT89C55
programming new series ATMEL 89S5152538252
Simple AVR Programmers
SPI Flash Microcontroller Programmer
USB Programmer Atmel AT89C20514051
USB Programmer zum Flashen von Atmel AT89C20514051 Mikrocontrollern
yet another AVR programmer
eline sağlık teşekkurler.
çok teşekkürler emeğinize sağlık
emeğine sağlık kardeşim çok teşekkürler.
Emeğine sağlık çok iyi bir arşiv
atmel ilgili projem var ama ecilips programı kullanıyoruz ama arayüzü bir türlü anlayamadım atmel ile ilgili daha fazla döküman yayınlarsanız sevinirim AT91SAM7X256 özellikle bu model
selam kardeş . Dosya silinmiş yazıyor yeniden yüklemeniz mümkünmü?
linkler yenilendi
