12V 230V DC-AC Mosfetli Basit İnverter Devresi
basit-230volt-220volt-inverter-devresi
12v-230v-50hz-60hz-invertor 12v-230v cd4047-mosfet
12V 230V İnverter Devresi cd4047 cmos monostable/astable multivibrator entegresi üzerine kurulu 12v akü voltajı 230v ac olarak yükseltiyor çıkış frekansı 50hz ya da 60hz olarak ayarlanabiliyor.
12volt-220volt-inverter-devresi
The power converter 12/220
  • Input voltage 12V DC
  • Output 230V AC /50/60Hz rectangular course.
  • The possibility of changing the frequency of 50Hz to 60Hz.
  • The effectiveness of at least 80-85%.
This simple converter can serve as a source of tension for 230V/50Hz appliances according to the input of the transformer, which may be compact fluorescent lamps, fluorescent lamps classic, small motors, razors, power TVs and other consumer electronics, backup gas boilers for the failure. proudu a pod. current and under. finds application not only
the ship and everywhere where there is no grid 230V. Participation is easy. The rectangular generator used during 50Hz monostable flip-flop in 4047 are available in the output pulses which are the alarm four MOS switches involved in the bridge connecting alternately winding 10V transformer to supply voltage 12V. the output level of 11 L, which is sepnut transistor T2 conductivity P. The presence of voltage 230V signals produced doutnavka. Prepínacem Pr1 lze menit frekvenci generátoru z 50Hz na 60 Hz. PR1 switch can change the frequency generator
Formal parameters:
  • Trafo 40W contained in the kit:
  • Voltage 260V
  • current 400 mA
  • voltage lamp 25W 230V
  • collection 25W at 2.5 A
  • voltage lamp 40W 220V
  • 3,8A the collection burden 40W 3,8
Other trafo on performance 100W/230V/10V
  • 270V Voltage 270V
  • current 800 mA
  • voltage lamp 40W 225V
  • voltage lamp 60W 210V
  • the collection 60W
inverter
  1. hüseyin says:
    Teşekkürler
  2. ümit says:
    Teşekkürler
  3. ulu neco says:
    tam 10 yıldan beri inverter devresı yapacam hala zamanım olmadı bakalım nasip bu devre heralde tipini sevdim
  4. EMRAH says:
    kolay gelsin 12V 230V DC-AC Mosfetli Basit İnverter Devresi yukarda adı gecen devrenini şeması yok ne işe yarar şemasız rica etsem yardım edermisiniz
  5. tar says:
    emrah bey resmin altınaki linki tıklayınca açklama da şeada çıkıyor
  6. muzo.muco says:
    şema görünmüyor bana mesaj atarmısınız şema resmi de olur :)
  7. gevv says:
    En üstteki büyük resimin altındaki “The power converter 12/220″ yazısına tıklayın şemayı göreceksiniz
  8. ali says:
    şema görünmüyor
  9. şevki says:
    devre şeması üzerinde elemanların hepsinin değerleri yok.eleman listesini nereden bulabiliriz
  10. yusuf erkul says:
    Arkadaş bu devre çıkışında 12 v veriyor ama sorun trafoya bağladığımda 220 v alamıyorum nedenini bilen varsa söylesin lütfen
  11. Burak says:
    bende bulamadım elemanların hepsi yazmıyor. devreyi yapan arkadaşlar bir liste yazabilir mi? cok teşekkürler.
  12. Emin says:
    Devrede 10V istenmiş, ben 12V trafo kullanacağım, ne gibi değişiklikler yapmam gerekli.
    Malzemeler: 390Kohm, 82Kohm drenç. 10nF kutupsuz, 1000uF 25V kuktuplu kondansatör. cd4047 entegre, IRF9540 veIrF540 transistör. 220V to 10V transformatör. Devre çıkışındaki drence ve kontrolkalemi ampulune gerek yok sanırım. Bakır delikli plaket iyi lehim yapanlar için. Devre bitiminde yağsız tinerle temizle ve vernikle tamam.
Yorum Sayfaları
