Elektronik Devreler Projeler » Atmel devreleri bilgiler, Microchip PIC devreleri bilgiler »
Mikrodenetleyici Kontrollü Metal Dedektörü Projeleri
PIC16F873A 28 PIN Clone PI
Result of displays in the form of two scales, which are estimated to judge the material goal.In addition, the screen is small scale level of response and the current supply voltage. PIC18F252 The program is intended for controller PIC18F252.The controller PIC16F873 (A) to this version can not be used. This is more demanding to resources controller. 252nd compatible controller on “pins” with 873 – m and can be programmed by the same programmer. The program workable only with korzinochnymi reels! R21 For this firmware needed zakorotit resistor R21 (in the old version of the scheme). In this version the appointment of buttons changed to read
ATMega32 ClonePI-2
ClonePI-2 is a further development of the project ClonePI). The main objectives in the design – to get discrimination metals
ATMega8 ClonePI AVR
ClonePI AVR is a so new simplistic solution pulse metal ClonePI)
# Use ATmega8 controller available from Atmel.
# Instead of using an external ADC ADC internal controller.
To get the same sensitivity as to the external ADC, is used oversampling.
# Use taktirovanie of internal RC-generator controller.
ATMega8-16PI ClonePI-W
Instead of LCD used LED display. Cut down on administration, leaving only the most necessary. Take into account some errors in previous versions.
Metal dedektör devrelerine ait detaylı açıklama (ingilizce) ve devre, şema kod dosyaları var. Dosyalar: mikrodenetleyici-kontrollu-metal-dedektoru-projeleri.RAR
  1. cetin bakic says:
    bu dedektörlerin derinlik sinyali ne kadar ve başarı oranı arazinin toprak yapısı değişince algılaması gerekli bilgeleri verirmisiniz
