Elektronik Devreler Projeler » Atmel devreleri bilgiler, Microchip PIC devreleri bilgiler »
GSM Alarm ve Kontrol
atmel_pic16f84_gsm_kontrol_role
Şuan oldukca populer bir konu Microchip pic serisi ile Cep Telefonu ile Kontrol bu tür proje yapmak isteyenler için ip ucu verebilecek feyz alacakları bir kaç proje aralarında 1 adet atmelli projede bulunmakta
AT90S2313 ile pc bağlantılı bir devre pcb dosyası ve asm hex yazılımları bulunmakta
at90s2313-gsm-alarm1
Emergency equipment is often equipped are various signs of tampering. The easiest is to run the audible signal or optical, the more advanced can given its status over the Internet or telephone. Presented in this article to your amateur alarm, which can send information on the attached by short text messages, so-called SMS. For model needs the company I used GSM modem Wavecom, but you can use any phone phone. Perhaps its use will require a solution to the problem of power and how encoding text messages, but it is possible and feasible in terms of electronics workshop – amateur.
The whole program has been constructed and compiled by AVR STUDIO 4. This is a complete environment for writing and applications for the AVR microcontrollers. The line RESET, MISO, MOSI and SCK przylutowałem microcontroller interface and programmer using ISP program and tested layout. This is a very comfortable not only for the amateur electronics, method. Allows you to run applications in real – its operating environment. The program occupies 128 bytes of EEPROM memory in the variables defined by the user. Their list can be found in Table takes 1,019 words double-byte, 2038 is 2048 bytes of program memory AT90S2313. Unfortunately, there is already too much space to implement the new functions or more messages. You can only be done
cost of removing or optimizing existing ones.
İkinci devre gsm controller pic16f84 üzerine kurulu 6 adet röle kontrol edebiliyor
c_502_gsm_kontroler_pic16f
It is a device that will include / exclude consumers when he sent the SMS. I did. The device consists of a PIC microcontroller, one ULN2803A (order transistor) power relays, and 6 relays. Of course, a few resistors and capacitors, three prekidačića, crystal and two LE diodice. The device was tested on Siemens phones, S25 and C35i. You should work with the other, and with all other GSM device which can be attached to the serial communication. Such devices are, for example.: All-Ericsson, and only with them I have not yet tested.
Üçüncü devre pic16f84 üzerine kurulu 4n35 opto kublor ile izole kontrol sağlıyor hex ve pcb dosyaları var
pic16f84a_gsm_kontrol
GSM Call Alarm is a device that uses a number of target position Siemens or Ericsson Mobile Phone (19200 bauds RS232) and sensory input is 1 and one entry – the state. If state = 0V then the device is “active” and follow the state senzorskog inputs. The device is “disabled” otpajanjem on / off (the state) with the mass of inputs (0V), or connect to the + half of power. Sensory input also respond to 0V.
Devre 4 16f84a ile yapılmış eeprom haberleşmesi (24lc515) yapılmış pcb ve hex dosyaları bulunmakta
pik_sms_alarm_devresi
SMS Alarm is a very simple device. To send a message uses a Siemens phone has 5 inputs – is sending 5 different messages. For each sensor uprogramiramo appropriate message you wish to receive the mobile when it is activated. Programming is done via the PC’s corresponding program which is attached in the archive.
Tüm gsm alarm devrelerinin dosyaları  pic_atmel_gsm_alarm_kontrol.rar
  1. okan says:
    ya bu devrenin çok basit olanı vardı artık sitede bulamıyorum sensörler hareketi izliyorlar hırsız olduğu anlıyor bağlı olan telefondan pic yardımıyla istenilen telefonu ya arıyor ya msj çekiyor tuş takımı falan da oyk çok basitti ama bulamıyorum admin lütfen yardım
  2. SERKAN says:
    selam arkadaslar ben cep tel ile su motorunu açıp kapatmak istiyorum bana yardımcı olurmusunuz.
