Electronic Workbench Devreleri EWB Circuits
Electronic Workbench Programı ile Simule edebileceginiz programda bulunan çeşitli ölçüm cihazları ile analizini yapabileceginiz hazır devreler
10 KANALLI ECOLAYSER.EWB
10 LU YÜRÜYEN RİNG SAYICI.EWB
YARıM DALGA DOĞRULTUCU.EWB
TAM DALGA DOĞRULTUCU.EWB
KÖPRÜ TIPI T.D.D..EWB
DIMMER DEVRESI.EWB
YÜKSEK GEÇIREN FILTRE.EWB
VEYA KAPıSı DENEYI.EWB
KAPILARLA OLUŞAN DOĞRULUK TAB..EWB
LOJİK DOĞRULUK TAB. (2).EWB
BOOLEAN MAT. AÇIKLAMA DOĞ. TAB..EWB
DOĞ. TAB. VERİLEN DEVREYİ ÇÖZME.EWB
4 BİTLİK SAYICI.EWB
YUKARI SAYICI.EWB
WORD JENERA. VE LOJ. ANALİZÖR.EWB
4 BITLIK SAYıCı.EWB
TOPLAYICI DEVRESİ.EWB
CD4017 ONLU YÜRÜYEN ıŞıK.EWB
TRANSİSTÖRLÜ ASTABLE MULTİVİBRATÖR.EWB
NE555 ENTEGRELİ ASTABLE MULTİVİBRATÖR.EWB
ENT.DEVRE.EWB
NE555 ENTEGRELI.EWB
NE555 ENTEGRESI ILE YAPıLAN ZAMANLAYıCı.EWB
NE555 ENTEGRESIYLE YAPıLAN ASTABLE MULTI..EWB
NE555 ENTEGRESIYLE YAPıLAN FR.AYAR.ASTABLE MULTI..EWB
A”+B”=A+B IŞLEMINI DOGRULAMAK.EWB
A’+B’=A’CARPı B’ IŞLEMINI DOGRULAMAK.EWB
AC GERILIMDE CALıSAN TRIS.DRN.VE KOND.YARD.TETIK..EWB
AC GERILIMDE ÇALıŞAN TRIS.DIYAKLA TETIKLENMESI.EWB
A’CARPı B’=A’+B’ IŞLEMINI DOGRULAMAK.EWB
ALARM DEVRESI.EWB
ALTERNATİF SİNYAL ÜRETECİ.EWB
AND VE OR KAPıLARıYLA XOR ÇıKıŞı ELDE ETMEK.EWB
BASİT ÖLÇÜMLER.EWB
BASIT RÖLE DEVRESI.EWB
COLPITS OSILATÖR.EWB
ÇIFT KARARLı MULTIVIBRATÖR.EWB
DC AC KONVERTISÖR.EWB
DC GERILIMDE Ç. TRIS.KAPASITIF ANAH. DURDURULMASı.EWB
DC GERILIMDE Ç. TRIS.PARELEL ANAH. DURDURULMASı.EWB
DC GERILIMDE Ç. TRIS.SERI ANAH. DURDURULMASı.EWB
DIYAKLı OSILATÖR.EWB
DIYOT VE DIRNÇLE YAPıLAN VE KAPıSı.EWB
ELEKTRONIK MERDIVEN OTAMATIĞI.EWB
ELEKTRONİK YAZISI.EWB
FERHAT.EWB
FET’LI COLPITS OSILATÖR.EWB
FLİP FLOP.EWB
GERILIM IZLEYICI OPAMP.EWB
İKI TRANSISTÖRLÜ UZUN ZAMAN(TURN ON).EWB
IKI TRNLI UZUN ZAMAN GEÇIKMELI DEVRE (TURN ON) TIPI.EWB
İNTEGRAL ALıCı OPAMP.EWB
JK FLIP-FLOP’LARLA MOD-6 ASENKRON SAYıCı.EWB
JK FLIP-FLOP’LARLA ÜÇLÜ YÜRÜYEN ıŞıK.EWB
KARŞıLAŞTıRıCı OPAMP.EWB
KOD ÇÖZÜCÜ (DECODER).EWB
KOD ÇÖZÜCÜ(DECODER).EWB
KODLAYıCı (ENCODER).EWB
KODLAYıCı(ENCODER).EWB
KRISTAL OSILATÖR.EWB
LAMBALARıN KARŞıLıKLı KARARTıLMASı.EWB
LKARE DALGA ÜRETECİ.EWB
LOJIK SEVIYE TESBIT DEVRESI.EWB
MELODİLİ KAPI ZİLİİ.EWB
MERDİVEN OTOMATİĞİ.EWB
NAND KAPıLARıYLA OR KAPıSı GERCEKLESTIRMEK.EWB
NOR KAPıLARıYLA AND KAPıSı GERCEKLESTIRMEK.EWB
OP-AMP’Lı KARŞıLAŞTıRıCı(SCHMITT TRIGGER TIPI).EWB
OP-AMP”Lı KARŞıLAŞTıRıCı.EWB
ORTAK KATOTLU 7 SEGMENTLI DISPLAY DENEYI.EWB
OYUNCAK KORNA DEVRESI.EWB
RÖLENIN ILETIM YALıTıM KA..EWB
SAYıCı 4 BIT.EWB
SAYıCı 5 BIT.EWB
SAYıCı 6 BıT.EWB
SCHMITT TETIKLEYICI.EWB
SCHMITT TRIGGER TURN ON ZAMANLAYıCı.EWB
SESLE KONTROL DEVRESI.EWB
SEVIYE.EWB
SİNÜS DALGA ÜRETECİ.EWB
STANDART RİNG SAYICI.EWB
TAM DALGA DOĞRULTMA OPAMP.EWB
TEK KARARLı MULTIVIBRATÖR.EWB
TERSLEMEYEN YÜKSELTEÇ.EWB
TERSLEYEN YÜKSELTEÇ.EWB
TOPLAYıCı YÜKSELTEÇ.EWB
TRANSISITÖRLÜ RC FAZ KAYMALı OSI..EWB
TRISTÖRÜN DC GERILIMLE TETIKLENMESI.EWB
TRIYAĞıN BIR DIRENÇ ÜZERINDEN TETIKLEN..EWB
TRIYAĞıN DC GEYT GERILIMI KULLANARAK TETIKLEN..EWB
YÜRÜYEN PANOLAR.EWB
EWB devreleri tüm dosyalar: electronic-workbench-devreleri.rar
Yazarımızın 320volt.com Blog üzerinde şu an okuduğunuz yazı dahil 1952 yazısı bulunmaktadır. Yazarımız hakkında bilgileri ve diğer yazılarını görmek için bakınız; gevv
böyle bir hazineyi biz meraklılarına sundugunuz için teşekkürler..
aga sayende dersten iyi not aldım… eyvallah
;) slm bu siteyi hizmete açanlara bu sayade Türki’ye bir adım daha ileri gidecektir sakın olaki bu siteden ne olurki demeyi size başarılar dilerim..
diyakla yapılan osilatör devresini bulamıyorum lütfen yardımcı olun :(
Çalişmalarınızın devamını dilerim. Allah razı olsun …
bende devreleri indirdim ama workbench devreleri açmıyo acaba proramın sürümü mü desteklemiyo arkadaşlar siz hangi sürümü kullanıyorusunuz 5.12 mi yoksa mültisim mi
Zamanında multisim 8 ile denemiştim bazıları açıldı bazıları açılmadı açılmayanlar daha eski sürümlerde açılır tahminimce
Paylaşımın için çok teşekkür ederim başarılarınızın devamını dilerim…
Multisim 10 kullanıyorum ama kütüphanem de bazı modeller eksik örnegin MC9S08QG8 or AT91SAM7X256 bu modellerin nerden bulabilirim veya diğer bir deyimle nasıl yeni library eklerim.Paylasımlarınız için teşşekürler.
Allah razı olsun ne yapacağım diye düşünürken süper oldu bu devreler sağ olun :D
Böyle bir paylaşım için teşekkür ederim…
