Elektronik Devreler Projeler » Programlama test devreleri »
ARM7 LPC2138 için Çok Amaçlı Kontrol Kartı
The Single-chip 16/32-bit microcontroller LPC2138 is an ARM7 microcontroller from NXP in a 64pin housing a wealth of peripherals, and myself as a basis for control projects. The board is described in an area of 100mm x 75mm functions
- An LCD port
- einen JTAG Port — A JTAG port
- Power supply 5V and 3.3V
- Voltage regulator as TO220 or SOT223
- 2x UART with RS232 transceiver
- Space for a 3V lithium battery
- A signal
- A real-time clock
- All I / O ports are placed on posts plug
lpc2138-development-board-Single-chip-16-32-bit-microcontroller-LPC2138
Kaynak: http://www.viricom.de/viritec/elektronik/page5_files/category-mikrocontroller.html alternatif link: arm7-lpc2138-icin-cok-amacli-kontrol-karti.rar
  1. ArGeMaNiA says:
    Çizimlere nasıl ulaşıyoruz.
  2. gevv says:
    sitenin içeriği değişmiş yeni adres: http://www.viricom.de/viritec/elektronik/elektronik_projekte.html
