555 Timer Desinger astable monostable hesaplama
Elektronikte kullanımı oldukca yaygın NE 555 timer entegresi için hazırlanmış bir hesaplama programı hesaplamalar örnek 555 devreleri ile yapılıyor
555 Entegresinde Astable,Monostable hesap yapabileceginiz ayrıca örnek uygulama şemaları bulunan Güzel bir Program
555 Timer Desinger 555 devreleri_tasarim.zip
555 Timer astable monostable calculation Desinger
Design Mode
1 Enter frequency (or delay) and duty cycle, if applicable.
2 Click on calculate.
3 Change capacitor values with up/down arrow keys.
4 To enter standard or measured component values, place
cursor over component (R1, R2, or C1). The cursor design will change. Click on component, and enter new value. Note that now the frequency (or delay) and duty cycle will be recalculated. Values can be adjusted within +/- 20% range
Applications (hazır devreler)
Triggering in monostable mode
Missing pulse detector
Driving inductive load
Frequency divider
Tone burst generator
Sequential (cascaded) timer
Long interval timer
Driving a speaker
Voltage-controlled oscillator
Pulse width modulator
Exact square wave astable
Positive to negative DC converter
DC to DC converter
DC voltage doubler
http://www.schematica.com
hocam link kırık galiba kontrol ederseniz sevinirim selamlar
link yenilendi Teşekkürler
