USB Nimh Nicd Pil Şarj Devresi
usb_nicd_pil_sarj USB Nimh Nicd Pil Şarj Devresi
Devre LM393 Op-amp üzerine kurulu bilgisayarın USB portundaki 5 volt ile 2 adet AA NiMH, NiCd pili şarj edebiliyor. Şarj akımı 470mA devreye ait pcb çizimi ve detaylı bilgi (ingilizce) var.
usb-charger-circuit-testing-pil-sarj-devresi
During charging, R1, R2, and R4 form a three-way voltage divider which yields about 1.26V at the non-inverting input of Z1a (pin 3, Vref). TR1 is a thermistor that is in direct contact with the cells being charged. It has a resistance of 10k at 25°C (77°F), which varies inversely with temperature by about 3.7% for every 1C° (1.8F°). R3 and TR1 form a voltage divider whose value is applied to the inverting input (pin 2, Vtmp). At a temperature of 20°C (68°F), TR1 is about 12k, which makes Vtmp about 1.76V.
The charger in this project is designed to charge two AA NiMH or NiCd cells of any capacity (as long as they are the same) at about 470mA. It will charge 700mAh NiCds in about 1.5 hours, 1500mAh NiMHs in about 3.5 hours, and 2500mAh NiMHs in about 5.5 hours. The charger incorporates an automatic charge cut-off circuit based on cell temperature, and the cells can be left in the charger indefinitely after cut-off.
usb-battery-charger-schematic usb-pil-sarj-devresi-baski-devre-pcb usb-charger-placement
Size: 3.8″L x 1.2″W x 0.7″H (9.7cm x 3.0cm x 1.5cm).
Cells: Two AA, NiMH or NiCd
Charging Current: 470mA
Charge Termination Method: Battery Temperature (33°C)
Trickle Current: 10mA
Power Source: Desktop, Laptop, or Hub USB port
Operating Conditions: 15°C to 25°C (59°F to 77°F)
Pil Akımı Şarj Süresi
700mAh NiCd 1.5saat
1100mAh NiCd 2.5saat
1600mAh NiMH 3.5saat
2000mAh NiMH 4.5saat
2500mAh NiMH 5.5saat
Kaynak: USB Powered AA NiMH and NiCd Battery Charger Alternatif link: usb-nimh-nicd-pil-sarj-devresi.rar
  1. murat says:
    devreyi yaptım, transistorun ısınması devrenin çalıştığını gösteriyor…fakat 2,3 a lık pilleri taktığımda, maksimum 1,5 saat şarj ederek kesiyor ama piller tam dolmuyor, sebebini bilen varmı?
    devrede bd244 kullanılabilir ama soğutucu gerek
  2. ozan says:
    merhaba arkadaşlar ben bu şarj aleti ile 3 tane aaa pili şarj edebilirmitim devrede değişiklik yapmaya gerek varmı
  3. Olcay says:
    Arkadaslar birsey sormak istiyordum ?
    ilk once turkcem sayif oldugu icin uzul dilerim ama insallah anarsiniz nedemek istedigme
    Soru su >
    Benim bir kaynak var ve degisik voltage uretiyor 1 volt ve 15 volt arasi gidip geliyor
    simde bu dengisis voltage da nasil bir aku sarj edebilirim ?
    tesekurler
    Olcay
  4. sefa says:
    devre şemasını bulamıyorum. yardımcı olun
  5. Ceyhun says:
    Devre denendi mi acaba bilgilendirirseniz sevinirim.teşekkürler.
  6. murat says:
    Selam ustad ben bu projeyi anlatildigi gibi yaptim butun mazemeleri eksiksiz aldım aynısı yanlız tip 32 yoktu 42 kulandım resimdeki gibi monta ettim ikincisi değişik olan 0.1 uf 10v olacaktı bulamadım 01uf 50v kulandım bunu harici bütün kondansatör değerlerini aynı kulandım ama bir türlü olmadı çalışmıyor.
    Led in ayaklarinda + var biri – biri + olması lazım artı yönünden gelen + doğru – yönünden gelen de + neden diye düşündüm anlayamadım ohm leride resimdeki gibi ekledim gold taraflarına baktım gold çıkış oluyor galiba onlarıda aynen resimdeki gibi lehimledim ama bir türlü çaliştıramadım.
    Kafam hep şu LM393N ye takıldı hangi tarafı doğru anlayamadım çevirip iki türlüde lehim yaptım ama olmadı neden acaba aslında çok önemli değilde ben bu site sayesinde can sıkıntısını gidermek için kendime bir hobi seçtim ilk denemede olmadı ama inanki 3 gündür denemediğim kalmadı bütün bu konuyla ilgili siteleri baktim burada da inceledim orjinal sitesinede baktım çıldırdım en sonuda yanlış nerede yapmış ola bilirim kesinlikle pil sarj yuvasına akım gitmiyor ama termistörü elektirik doğru değerde geliyor bilmiyorum daha ne yazayım bana bir akıl ver bilirmsin yoksa rafamı kaldırayım bu nu başka bir devremi yapayım bana bir yol gösterin şimdiden teşekkürler
  7. gevv says:
    @murat hocam keşke biraz daha erken saatlerde yorum yazsaydınız :) şema hazırlardım ama saat şuan 00:10 bu gün baya yorgunum
    projeyi rafa kaldırmayın yarın akşam işten geldiğimde sizin için devrenin basit 3d şeklinde çizimi hazırlarım daha kolay kontrolleri yaparsınız
    iyi çalışmalar
  8. murat says:
    üstadım sana çok teşekkür ederim yardımların için bekliyor olacağım 3d yardımını şimdiden teşekkürler.
  9. gevv says:
    hocam umarım işinize yarar iyi çalışmalar
    lm393-usb-pil-sarj-devresi-usb-charger usb-charger-completed
  10. murat says:
    üstadım teşekkür ederim bu çok işime yaradı benim hatalarımda otomatik ortaya çıktı yeni yayınladığın 1 resim her şeyi ortaya koymuş süper teşekkür ederim ustam bunu bugün tamamlayıp size sonucunu yazacağım teşekkürler.
  11. Murat says:
    biraz geç oldu ama bu arada bazı işlerim çıktı devreyi tamamladım çalışıyor hatayıda buldum kendimce lm393 bağlantı hatası yapıyormuşum onuda halletim isik yandı ışığı artırdım ışık söndü ama alamadığım pil yuvasına sanki enerji gelmiyor şimdilik bilmiyorum iki tane aa aku alıp deneyeceğim
  12. halil says:
    arkadaşlar devreyi yaptım pil yuvasına enerji geliyor ama led yanmıyor neden olabilir acaba?
Yorum Sayfaları
