Tda serisi anfi entegreleri döküman designers guide
tda-anfi-entegreleri-philips
Philips firması tda serisi anfi entegreleri için bir döküman hazırlamış piyasadaki bir çok tdaxxxx anfi entegresi hakkında detaylı bilgi (güç, çalışma voltajı, frekans vb.) ve televizyonlar,müzik setleri, ses sistemleri için devre şemaları bulunuyor aşağıda özet verildi
Kaynak: Audio power amplifiers alternatif link: tda-anfi-entegreleri
AUDIO AMPLIFIER ICS DESIGNER’S GUIDE
  • Product survey and page reference
  • In application sequence
  • In power output sequence
  • Audio amplifier ICs for portable radio/audio equipment
  • Audio amplifier ICs for car radios/power boosters
  • Audio amplifier ICs for mains-powered systems including hi-fi and TV sound
  • Appendices, Further information, Data
  • Application notes and leaflet
  • Index of audio amplifier ICs
tda1514a-mono-anfi
tda1514a-kopru-bridge
 TDA1010A/1020    Preamplifier plus 3,4 to 12 W power amplifier
 TDA1011    6,5 W amplifier
 TDA1013B    4 W to 10 W amplifier with DC volume control
 TDA1015    4 W amplifier
 TDA1015T    500 mW amplifier
 TDA1016    2 W power and record/playback preamplifier
 TDA1308T    2 × 60 mW headphone/line output driver
 TDA1510AQ/1515BQ    24 W BTL or 2 × 12 W amplifiers
 TDA1514A    50 W high-performance hi-fi amplifier
 TDA1516BQ/1516CQ/1518BQ    24 W BTL or 2 × 12 W amplifiers
 TDA1517(P)/1519    2 × 6 W amplifiers
 TDA1519A/1519B    22 W BTL or 2 × 11 W/12 W BTL or 2 × 6 W amplifiers
 TDA1521(Q)/2616(Q)    2 × 12 W hi-fi amplifiers
 TDA1521A/2615    2 × 6 W hi-fi amplifiers
 TDA1552Q/1553Q/1553CQ/1557Q    2 × 22 W BTL amplifiers
 TDA1554Q/1555Q/1558Q    2 × 22 W BTL or 4 × 11 W amplifiers
 TDA1556Q    2 × 22 W BTL amplifier with differential inputs
 TDA1560Q    40 W class-H amplifier
 TDA1561Q    2 × 23 W high-efficiency power amplifier
 TDA2611A    4 W to 10 W amplifier
 TDA2613/2614    6 W hi-fi amplifiers
 TDA7050(T)    150 mW BTL or 2 × 75 mW low-voltage amplifier
 TDA7052/7053    1 W/2 × 1 W BTL amplifiers
 TDA7052A(AT)/7052B(BT)    1 W/0,5 W BTL amplifier with DC volume control
 TDA7053A(AT)    2 × 1 W/0,5 W BTL amplifier with DC volume control
 TDA7056/7057Q    3 W/2 × 3 W BTL amplifiers
 TDA7056A/7056B    5 W BTL amplifier with DC volume control
 TDA7057AQ    2 × 5 W BTL amplifier with DC volume control
 TDA8541(T)    1 W BTL amplifiers
 TDA8542(T)    2 × 1 W BTL amplifiers
 TDA8543(T)    2 W BTL amplifiers
 TDA8547(T)    2 × 1 W BTL amplifiers with standby selection
 TDA8551(T)    1 W BTL amplifiers with digital volume control
 TDA8558(T)    Low-voltage BTL mono amplifiers
 TDA8559(T)    Low-voltage BTL stereo amplifiers
 TDA8560Q/8563Q/8563AQ    2 × 40 W BTL amplifier with diagnostics
 TDA8561Q/8564Q    2 × 24 W/4 × 7 W amplifier with diagnostics
 TDA8562Q/8565Q    4 × 12 W amplifier with diagnostics
 TDA8566Q    2 × 25 W BTL power amplifier with differential inputs
 TDA8567Q/8568Q/8569Q    4 × 25 W BTL amplifiers
 TDA8574(T)    Dual common-mode rejection differential line drivers
 TDA8577    Dual common-mode rejection differential line driver
 TDA8576T    Dual common-mode rejection differential line driver
 TDA8578(T)    Dual common-mode rejection differential line driver
 TDA8579(T)    Dual common-mode rejection differential line receiver
tda2615-tda2616-tda1521a-anfi-stereo-mono tda8579-anfi-amplifier-ses-tda
  1. mustafa says:
    Sağ olun
  2. ethem says:
    elektronikte yeniyim (aslında ilköğretim 6.sınıftayım)ama elektroniğe çok meraklıyım bilgi için teşekkürler inşallah işime yarar
