450w_bjt
UMZCH 450 watt
2cs5200_2sa1943_450w
In this UMZCH used modular design, so called.it is divided into two logically completed block: amplifier output voltage and powerful repeater. This allows, if necessary, or for the sake of the experiment apply different circuitry data nodes.You can mix tube amplifier output voltage and transistor cascade. Similarly, the output cascade can be executed as a bipolar transistor, and at the MOSFET
180 watt
about 180 W power per channel into 4 ohms
of output transistors 2sa1943 2sc5200
supply voltage amplifier + -45-50 In order
voltage amplifier still remain, with face values of resistors slightly modified
power supply - the total for both channels
Pcb ve şema Dosyaları P-CAD ile hazırlanmış ücretsiz izleme programını buradan indirebilirsiniz
badlink
