pic16f876a_7-segment
Big 7segment
PIC16F876A to be used to control all of task on this project.You can replace with any 28 pin PIC microcontroller.PortB set as output to drive all segments.PortC set as output to drive each digit vai ULN2803 which is octal hight voltage high current darington transistor array
The example firmware included in this project is 4digits counter writen for CCS C compiler
counter_ccs_c_compiler
