PIC12F629 PWM Kontrol EI33 SMPS
pic12f629_pwm PIC12F629 PWM Kontrol EI33 SMPS
PWM Kontrolü 12f629 mikrodenetleyici ile yapılıyor GP0, GP1 çıkışlarında BUK555 mosfetler ile EI33 smps trafosu sülürmüş. Devrenin çalışma frekansı 25kHz
It is a chopper to 25 kHz built around a PIC12F629 to operate on a 12V battery.It uses a transformer recovered in a power PC.The holding power has been tested up to 50 W, the secondary is wound depending on the need
Primer
pic12f629_pwm_primer
Sekonder
pic12f629_pwm_sekonder
Kaynak: PIC12F629 Hacheur alternatif link: pic12f629-pwm-kontrol-ei33-smps.rar
  1. Mesut says:
    Sanırım istedigim sey buydu :)
