PIC 16F84 ile İki Kanal Led Seviye Göstergeli Dimer
High power lamp control Maximum lamp brightness preset Minimum lamp brightness preset for filament preheating Automatic or manual dimming between brightness presets
Separate flash on and flash off Flash brightness preset Dimming rate programmable from instant through to 40 seconds A and B dimming rate selection Lamp brightness indication Automatic dim up and dim down indication
Kaynak: http://www.siliconchip.com.au/cms/A_30600/article.html Alternatif link: pic-16f84-ile-iki-kanal-led-seviye-gostergeli-dimer.RAR alternatif link2
kimsede bu devrenin şeması var mı? tamam, pcb’den çıkarılabilir belki ama ortada bir kaç kart var, oldukça karışık; epey zahmetli olacak.
