Mood P.I.L.L
“Mood Polycontrolled Interactive LED Light” ATMEGA168/88 üzerine kurulu garip bir RGB Led uygulaması
Projede tüm detaylar var (almanca) arrıca .bas .OBJ .HEX .BIN ve PCB Dosyaları var pbc Sprintlayout ile hazırlanmış izleme ve print için “Viewer for Sprint-Layout 5.0 Programını kullanabilirsiniz Proje Dosyalarına Buradan ulaşabilirsiniz
Kullanılan ana parçalar bulunurmu bilmem umarım piyasada vardır
LMC6482 (National Semiconductors, DIP ![]()
LIS2L02AS4-TR (ST, SOIC 24)
MAX712CPE+ (Maxim/Dallas, DIP 16)
ATMEGA168/88 (Atmel, DIP 28)
MAX603CSA+ (Maxim/Dallas, SOIC ![]()
HMC6352
Description
This device is capable of his two flares in different colors of the rainbow (color circle) to shine. It has three modes, a compass mode (mode 1), in which the two flares show the direction in which the device with its axis shows, a move mode (mode 2), in which the two flares its color depending on the situation of the unit in the X-and Y-direction change, and a program mode (mode 3), in which the two flares independently one from 8 colour change programmes can play. This device has a built-in rechargeable battery and can Volladung about 2 hours regardless of the network in operation.
