MC9S08QG8 ile Bluetooth Kontrollü Robot
Side-plate is used mainly to connect a Bluetooth module and the robot is without a fully functional, but it is not possible to wirelessly control.Mechanical construction is due to the use of the Best work very simple. The body of the robot is constructed of copper wire, such as power supply is used four AAA Ni-MH cells and wheels are mounted flat on the transmission shaft, which is already part of a motorcycle. Wireless control the robot via Bluetooth is control Programs and source code
The most important component main boards and thus the whole robot is MC9S08QG8 Freescale microcontroller in the case PDIP16 (IC1). UART, SPI a I2C. He has, for example, 8k bytes of flash memory for the program, 512 bytes of RAM, a 16-bit timer, one 8bit timer and communication interface UART, SPI and I2C. His HCS08 core optimized for programs translated into the source code from the C language may be due from an external source and frequency of 20MHz. maximum frequency adjustable internal resources stepping, which employed 8.3712 MHz.
Flash memory in the microcontroller is needed through BDM interface to load a program that can be downloaded here. This program takes care of turn on the engine using the couple IRF7303 MOSFET transistor (T1), which are integrated in a single housing SO8. Transistors are capable of operating current and 3.5 A, which is due to the engines used more than sufficient.
Kaynak: MC9S08QG8-bluetooth-robot alternatif link MC9S08QG8-bluetooth-robot.rar
Maliyeti ne kadar hocam bunun
Mearaba arkadaslar. Marmara üniversitaside okuyorum. Ben bu projeyi bitirme projesi olarak yapacağım. Bazı sorularım var. Sizinle görüşmem lazım. Benim mail adresim hakan_ozen@msn.com . İlgilenirseniz sevinirim. Şimdiden ilginiz için teşekkür ederim. LÜTFEN!!!
bende bu projeyi yapmak istiyrum ama hakan arkadaşımız gibi benimde aklımda takılan bir kaç soru var. bu yuzden benimlede kontak kurmanızı isterim mail adresim ycl_dmn@hotmail.com. sizin mail adresinizi bulsam oraya mail atacaktım ama onuda bulamadım. şimdiden ilginiz için çok teşekkürler.
Sorularınızı burada belirtebilirsiniz bilgisi olan kişiler cevap verebilir hem sorularınıza gelecek olan cevaplardan diğer okurlarımızda faydalanmış olur
Hocam dokumanı türkçeye çevirirseniz bir nebzede olsa soruları giderebilirsiniz ayrıca bu araç nasıl yapılmış kullanılan malzemeler neler telefonun modeli önemli kontrol için telefonu her hangi bir yazılım yükenıyormu?
bluetooth modülünü nerden temin edebiliriz modül bulunduktan sonra gerisi kolay
Bu projede Lap Top Bluetooth modülünü söküp kullanacağım merak ettiğim konu nasıl tanıtıcağım birbirlerine..
Yani Windows işletim sistemli telefon ile Bluetooth modülü nasıl birbirine tanıtıcağım ?
bu devreyi tamamlayan varmı? pic kodlarını bulamadım yardımcı olurmusunuz
Çok güzel ve basitleştirilmiş konular. Emeği geçen herkese teşekkürler.
hocam dökümanı inceledim bluetooth değil kızılötesi ile iletşim kuruyor
cep bilgisayarı ile kontrol edilebiliniyor
Bluegiga firmasının WT11 modülünü kullanmış olan arkadaşlar var mı acaba? Gömülü sistem projesinde kullanıyorum.
Merhaba arkadaşlar ben bluetooth ile bir proje yapmak istiyorum bitirme projesi olucak. Ne önerirsiniz ve burada bahsi geçen projeyi bitiren var mı?
