Devrede 12 adet lm339 1 adet lm393 opamp kullanılmış kanal başına 50 adet led düşüyor tüm parçalar piyasada bulunmakta pcb çizimi var Dosya ve detaylara buradan ulaşabilirsiniz
is on the Internet a lot, but the indicator with more than 15 LED Unfortunately, I have found. 2 x 50 LED. I have decided therefore to the design of a simple and relatively cheap indicator with 2 x 50 LED.
Technical data
Voltage: 12Vss stab.
Consumption: 10 mA to 1.2A
Initial resistance: 2.2 kOhm
Rozmery: 292 x 36 mm Dimensions: 292 x 36 mm
