mix-circuit
Çeşitli Kategorilerde Yüzlerce Devre çoğu basit kullanışlı işinize yarayacak bir devre mutlaka vardır :)
Karışık Devre Arşivini Buradan indirebilirsiniz
Alternatif
Arşiv içinde bulunan Devreler
Alarm Devreleri
modular burglar alarm
phone line cut alarm
radiowavealarm
radiowavealm
rainalarm
snore alarm
water alarm
latching relay alarm circuit
low voltage alarm
mobile radio on-alarm timer
proximity alarm
alarm clock timer
backup battery monitor-charger
burglar alarm circuit
car alarm
motorcycle alarm
motorcycle burglar alarm
proximity alarm
turn signal alarm
turn signal alarm circuit
voice activated swit
motorcycle alarm
personal alarm
alarm touch triggered
alarm universal system
alarm warning strobe flashers
backup battery monitor-charger-alarm
car alarm
cmos zone alarm
door knob alarm
frig door alarm
gate alarm
headlight alarm
auto burglar alarm2
car water temperature
sun-up alarm
555 - 741 Opamp Devreleri
555 timer a-d converter
alarm
buzz
car locator
delay
dimmer
flashing
logic probe
magnetic
mispulse
morse
morse1
morse2
neon
probe
pumpkin
relay
ringdelay
sensor2
servo2
servo3
siren
slammer
trnhorn
voltage doubler
water alarm
555 ignition coil driver
555 timer40khz ir
pulser
optical proximity switch
timer_circuits 555
12vdc fluorescent lamp driver
pagestyle
flampdrv
555 timer as an a-d converter
555 timer ic tester
555 logo
555 test
555 timer
alarm2
automatic device locator
basic ic monostable multivibrator
monostbl
codelock
juniortheremin
ne556 dual timer-oscillator
wailing alarm siren
74112mon
741-bg
741 boost
741 comp
741comp 2
741 equiv
741 low
741-null
741 peak
741-ps
heat sensor
relay
sensor
Alıcı Verici Devreleri
10mw fm transmitter
1w cw transmitter
30w fm verici
4 transistor transmitter
5w pll transmitter
7mhz qrp transmitter
80 meter dsb transmitter
active anten nawithgain
air craft radio receiver
am transmitter
loop antenna
crystal locked tone transmitter
fm transmitter
micro power am transmitter
sensitive fm transmitter
sing leval vecw transmitter
sparkgap transmitter
1.5 v fm transmitter
2 transistor transmitter
3 v fm transmitter
7 wam transmitter
am-fm receiver circuit
fm auto radio diversity antenna
fm bug
fm infrared receiver for audio rec
fm scanner noise squelch
fm stereo decoder
fm stereo transmitter
fm transmitter
nb fm audio amplifier
3 v fm transmitter
fm bug
fm stereo decoder
fm transmitter
tunable fm antenna booster
40k laser transmitter
rfss handie hopper transmitter
cb transmitter
walkie talkie
1 watt fm mİkrofon
1.5 voltla fm yayini
100 watt fm transmitter
20 watt fm transmitter
3 watt fm transmitter
360 watt fm transmitter
396 alıcı verici
3volt fm verici
4w verİcİ
75 watt fm transmitter
7w_pll
80 watt fm transmitter
fm transmitter
2w fm transmitter
3w fm transmitter
7w fm transmitter
coil-less fm transmitter
fm radio receiver
simple fm transmitter
miniature fm transmitter
ba1400-blok-cizim
ba1404-stereo-verici
fm-booster
Fan Kontrol Devreleri
sicaklik kontrol
pc fan
auto fan
cpu fan controler
fan failure indicator
fan speed control
automatic temperature controlled
fan durdu ikaz
Ir Wireless Devreleri
ır remote control tester
wireless rts with data
key wireless rts with data
wireless guiter transmitter
wireless microphone
wireless ir headphone receiver
wireless ir headphone transmitter
wireless microphone
infrared remote control
infrared logic probe
ir headphones
ir related ascii
photo diode amplifier
sam laser
colour meter
infrared transmitter decoder
ir link
ir rs 232 transceiver
ir type data link
led photo sensor
logarithmic light sensor
optical toggle switch
photometer
titleeg
infa-red remote control
irrec
infra red remote control extender
infra red repeaters
infra red switch
ir remote control extender
ir remote control modulation detec
irda transceiver for desktop pc
irda transceiver
pc related irda int
Osilatör,Timer,Test Devreleri
digi sound oscillator
dip oscillator
twotransistorsinewaveoscillator
2.6 ghz oscillator for radar speed
455 khz oscillator
am oscillator for wireless microph
astable oscillator 1
astable oscillator 2
basic lm3909 audio oscillator
beat freq oscillator am-sw radios
butler oscillator circuit
clapp oscillator for 100 khz
colpitts oscillator
colpitts oscillator-1
crystal oscillator 1
crystal oscillator with adjustable
crystal oscillator with fm capabil
darlington transistor oscillator
dc-switched crystal oscillator
digitally controlled square wave o
easily tuned sine-wave oscillator
fet quartz crystal oscillator
fm hf oscillator with no varactor
freq modulated oscillator
frequency doubler and crystal osci
gate dip oscillator 1
grounded base runed collector osci
hartley oscillator
jfet variable freq oscillator
logic gate sine wave oscillator
loop oscillator eliminator
low distortion sine wave oscillato
low frequency relay oscillator
modified hartley oscillator
one transistor phase-shift oscilla
oscillator circuit
oscillator triggered switch
quad tone oscillator
quadrature wave oscillator
reinartz oscillator
remote oscillator high freq vfo
reverse bias oscillator
simple code practice oscillator
simple variable freq oscillator
stabilized wien-bridge oscillator
455 khz oscillator
colpitts oscillator
crystal oscillator 2
crystal oscillator 3
gate dip oscillator 2
hartley oscillator
oscillator circuit
reinartz oscillator
tunable uhf oscillator
ttl audio oscillator
tuned collector oscillator
ujt 100-khz calibration oscillator
vlf lc oscillator
voltage controlled two phase oscillator
warble oscillator
bridge oscillator 1
zener oscillator
10 to 1mhz frequncy converter
frequency generator
collection of three clock generato
intermittetly pulse generator
wien bridge oscillator
battery tester
cable tester
connection tester
crystal tester
electrolytic tester
ir test
midi tester
mosfet tester
rj45 tester 1
rj45 tester 2
transformer short tester
xmas bulb tester
zener diode tester
adjustable continuity tester
audible continuity tester
automotive hi-z test light
imd test circuits for pin diodes
logic chip tester
power transformer tester
simple test signal generator
simple transistor tester
tests driver for hobby servos
logic chip tester
transistor tester
untrasonic remote control test
vcr head amplifier tester
transistor tester
untrasonic remote control tester
battery tester
dc voltmeter
digital volt and ampere meter
diode zener tester
frequency counter
frequency meter
frequency multiplier
high temperature alarm
loop back test card
opamp tester
test card generator
asym timer
budget timer
periodic timer
liquid cooling pump timer
dark room camera shutter timer
frequency divider
relay timer switch
timer buzzer and optocoupler
wide rage timer
24 hour timer
Bilgisayar Kontrollü Devreler
bilgisayarlar için seri port infra
pc cable_tester
9 - 9 pin nullmodem cable
amiga rgb to scart rgb
bİlgİsayar İle dİrenç ölçme
bilgisayar kontrollü reklam panosu
bİlgİsayar uygulamalari
bİlgİsayarla dünyaya hükmetmek
kablo kodak dc 240
composite video adapter
multiple vga monitors
fax modem interface
ir player
isa kart dİzayni
mono chrome
pc graphics card tv signal
joystick adapter
pc joystick interface circuits
joystick adapter
opto-isolated stepper motor control
rgb pinouts
rj45 network kablo test cİhazi
scsi connectors
remote control of computer
seri port infrared
ir alici kumanda2
sync on green
8 way relay board
vga to pal and ntsc video converter
vga to pal converter
vga to rgb sync converter
sync box
vga to tv converter
vga scart
vga 12mhz
video encoder
encoder
Telefon Devreleri
telephone activated switch
telephone headset
telephone line simulator
telephone ringer
telephone use indicator
universal telephone hold circuit
telephone bell amplifier
telephone call restrictor
telephone line tester
telephone recording circuit
telephone ring amplifier
telephone ring signal detector
telephone scrambler
telephone-audio interface
telephoneringer
iniversal telephone hold circu
telephone scrambler
clue engaged telephone line
2-line intercom-cum-telephon
parallel telephones with sec
simple telephone recorder
telephone controlled night l
telephone conversation recor
telephone line based audio m
telephone ringer
telephone tap
voice record playback
phone linestatus
phone line sentinel
spy for two telephone lines
telephone line monitor
telephone ringer
telephone ring detector
telephone call director
airtronics (am-fm) trainer cord
İzole telefon kayıt-yayın
telefon monİtörü
Video Devreleri
video stabilizer
delayed video trigger for scopes
dummy load and video detector for
lm1201 video amplifier
modulator for video
nintendovideoinverter
one of two video selector
rgb video amplifier
sample audio-video cable tester
sdjustable video -cable equalizer
simple gray-scale video generator
simple video gray-scale
modulator for video
rgb video amplifier
simple video gray-scale gen. f
twisted pair video driver-rece
two input video mux cable driver
vcr video detector controller
video amplifier circuit
video amplifier
video cable driver
video cable driver-1
video driver-amplifier
video if amplifier-detector
video line decoder 1
video line decoder
video line driver
video line receiver
video modulator hookup
video staircase generator
video summing amplifier
video titler
video titler
twisted pair video driver-receiver
video amplifier
video cable driver
video line decoder
video line driver
video line receiver
video switch
video titler
video driver
display adapters
rf circuit video
122 video devresi
tv vİdeo uydu radar devrelerİ
digital video processor
tv transmitter
et4-50hz
t89-50hz
rgb-fbas
v-f converter linear
vhf wattmeter
video amplifier
video signal emphasis
video edge signal enhancement
vide osw
video wire
