Maliyeti yüksek fakat çok güçlü amfi devresi elektroniğe yeni başladıysanız yeterli tecrübeniz yok ise yapmanızı tavsiye etmem. Anfi çıkış katında 14 adet mosfet (IRFP240 IRFP9240) kullanılmış Besleme voltajı oldukca yüksek +92 v -92v Dikkatli Olun
The 800 Watt AV800 amplifier is based on My 1kw Amplifier and shares the same topology and basic PCB layout. The only real difference is the number of Output devices that the unit uses. The 1kw design has 20 O/P devices, while the AV amplifier has 14 O/P devices. This amplifier can be used for practically any application that requires High power, low noise, distortion and excellent sound. Examples would be Sub-woofer amp, FOH stage amplifier, one channel of a very high-powered surround sound amplifier etc. The AV amplifier has four main stages of amplification. We will begin by looking at each stage in reasonable detail.
800W Amfi Devre şeması
AV800 PCB – 800 Watt Mosfet Anfi Dosyalarını detaylı Açıklama;
