800w_mosfet_amfi
irfp9240_irfp240_irf9610_irf610
Maliyeti yüksek :) çıkış katında 14 (IRFP240 IRFP9240)  adet mosfet kullanılmış Besleme voltajı oldukca yüksek +92 v -92v Dikkatli Olun
The 800 Watt AV amplifier is based on My 1kw Amplifier and shares the same topology and basic PCB layout. The only real difference is the number of Output devices that the unit uses. The 1kw design has 20 O/P devices, while the AV amplifier has 14 O/P devices. This amplifier can be used for practically any application that requires High power, low noise, distortion and excellent sound. Examples would be Sub-woofer amp, FOH stage amplifier, one channel of a very high-powered surround sound amplifier etc. The AV amplifier has four main stages of amplification. We will begin by looking at each stage in reasonable detail.
800 Watt Mosfet Anfi Dosyalarını detaylı Açıklamayı (ingilizce) Buradan indirebilirsiniz
Mosfet Data
IRFP240
IRFP9240
IRF9610
IRF610
