IRFP150 Mosfet ile 2-5v - 27-5v 2A Ayarlı Güç Kaynağı
Laboratory 2.5 - 27.5 V 2A max (alternatif link)
The primary device is an electronic workshop in the power supply stabilized. After 8 years to use simple 2 Voltage Power Supply (5V and 12V) concluded that the time for change. During the construction guiding principle: “The simpler the better, because the power supply is used for work, and not for the constant repair.
230V AC power supply (tolerance 10% -20%),Stabilizing linear
Output voltage regulated smoothly 2.5 - 27.5 V (linear regulation, the accuracy of stability 1%)
The regulation of electricity in 2 ranges 0.2 A and 2A (an accuracy of 10%)
Signaling work in the “current mode”,
Work continued even in the worst conditions (2.5 V 2A),
Switched off the transformer for power losses at low voltages,
Bipolar circuit breaker network
The combined weight of the casing only with mechanism and isolated from any system capabilities,
Stable housing Desk (metal).
27/10/2008 12:20 pm
merhaba:
arkadaÅŸlar 2×45v simetrik 200va torodial trafo kendim saracağım.kendi yaptığım bi makine ile…elinizde iÅŸime yarayacak bilgiler varsa paylaÅŸmanızı istiyorum.öncelikle hesaplama programı olabilir.kendim bi formülle yapıyorum yanlış çıkıyor.bunun dışında tüm iÅŸe yarayacak dökümanlar olabilir..tÅŸk ler
