320volt / Voltage LEDs Resistor Calculator
LED calculations in the table as you do not know what the current drawn by the LED value, enter it below 20 mA voltage information was given standard LEDs. In general, ultra-bright white LEDs outer plastic sheath becomes transparent colors of these LEDs is higher than the normal operating voltage, such as normal while the red LED 2v 3v works with ultra-bright red LEDs
RED 2V
ORANGE 2V
YELLOW 2.1V
GREEN 2.2V
BLUE 3.3V
WHITE 3.3V
led-anod-katod-ledler-led-bacaklari ultra-parlak-ledler
Single Led Resistors Calculation
tek led hesaplama seri led direnc hesaplamasi
Power Supply
  V
Led operating voltage
  V
Led operating current
  ma
Result;
Calculated Resistor Value
  Ω
Calculated Resistor Watt
  W
You can use the resistor value
You can use the resistor watt
  W
LEDs Series resistors Calculation
seri led hesap ledler
Power Supply
V
  V
  ma
Series Led number used
Result;
  Ω
  W
  W
Parallel Led resistors Calculation
paralel bagli led hesabi ledler
Power Supply
  V
  V
  ma
Parallel Led number used
Result;
  Ω
  W
  W
This LED resistance calculator is licensed from metku.net
