Position:Electronics Blog Power Electronics Smps Circuits UC3843 UCC37322 ETD29 12v 18v 5a DCDC convertor
DC-DC converter circuit uc3843 based on the power MOSFET driver 2 adet 50n06 (60V N kanal mosfet) bu mosfetleri sürmek için ucc37322 (mosfet driver) with 3843 amplified output diode output in the two bys28-90 dual common cathode 90 Volt 12.5 Amp rating of the circuit's output voltage can be adjusted Schottky diode (12Was 26volt) 5 18volt amps set to
Etd29 used transformer winding wire used in 3 0.8mm line connecting pieces 15 Hemmed round
Dcdc converter circuit diagram,pcb details and other drawings Here
uc3843-dcdc-cevirici-konvertor-donusturucu 18volt-dcdc
  • Output Current: 5A 18V (10Ampere instant)
  • Input voltage: 10 15DC
  • Operating Frequency: 40kHz
  • Productivity:% 95
  • Output voltage: 12 26In
  • Maximum output power 100W
  • Low-voltage protection : 9,2In
50n06, bys28, dc converter, DC convertor, dcdc, etd29, smps, uc3843, ucc37322,
320volt yazarları
Author: gevv
Published on 15.03.2009 UC3843 UCC37322 ETD29 12v 18v 5a DCDC convertor total post 1780
Random Post
Güç Kaynağı Test circuit electronic Yük TL072 0p-Amp Mini Combox
Electronic Projects | 320volt.com Turkey in Turkey dealing with the development of IT and electronics to provide nice service to our people has been established to contribute to the development. | Infrastructure WordPress | simple electronic circuits | circuits archive
