Position:Electronics Blog Author Projects Articles Electronic 2x32 Volt Supply with TL494 SMPS for Car Amplifier
TL494 2X32 Volt car amplifier için SMPS Besleme
I went into the business of auto amplifier :) 2I'm thinking of a supply circuit of the second amplifier x100w×32 volt output smps circuit over symmetric varmediğinden highest possible load tests are counted, but failed completely switched off, though I have no doubt a kit ready for sale (AVT 2732)
The original version of the circuit AVT2732 Kit
SMPS circuit above dcdc + – 32 for the Volt etd34 1mm wire for two primary pralel 2×5 permits tur secondary tek 1mm counted 2×12 turn
Auto SMPS circuit diagram
In addition to +12 PC power supply volt input section of planted + 5 If the filter coil volt outputs added +12 increased by an additional two pieces of filter coils and capacitors used output volt 2200uF 50 volt paralel
I did the first experiments with pc power supply transformer (ei33) I wanted to test the transformer according to the situation before the appropriate dealing with the wrap Ferrite corechoose a transformer winding transformer with pc power supply output is not thick enough I think. primary section 5 volt wire gauge adequate for the parallel port can be said that we use ends
But the number of turns of the output voltage is used for winding very thin and more 32 removes the problem volts autoleveling
I used to test the output transformer atx power supply connections
NOT 33 Ferrite cores used in the normal state of the power supply
Car amplifier to the use of the (contact numbers are given according to the circuit diagram)
like I said, I want to quit on the wide field of PCB transformer settled for current and voltage windings have two options is not suitable ei33 the nub roll the handing over with a thick wire or a different nucleus can use the public
diode bridge rectifier is used only on departure process, pc power supply circuit hurdalarından süktüğüm 12 volt output diodes used BYQ28E,What if F12C20C to bridge the gap 3 One sufficient
Sample connection diagram of diodes
Circuit, over-current,There are short-circuit protection 10k (P1) trimpot adjusted with dual LED common cathode (red, green,) the situation with the protection of the right connection gözlemliyebilirsiniz instant red led lights up green during normal operation
SMPS circuit for automatic operation of the system is running at half-time car rem (remote) has a connection to +12 Besides volt input fuse
If the car has run without installation in the section rem 12 v is probably campır instead of cable to be connected to remote kablosuda
Test Voltaj ölçümleri
2Finished version of X32 images Volt Auto SMPS Circuit
Caution: pdf file of important information for those who want to use the original pcb pcb reason I do not know, but the original drawing bc-type transistors, transistor layout aspects need to be careful that the opposite can see in the picture below
Pdf file, the list also given a list of materials with 10k resistors 1k resistor values ​​listed in the diagram note was written wrong Get your materials according to the circuit diagram
Aspects of the original pcb faulty faulty transistor
According to the statements in terms of the power supply circuit of the transformer and flexible power mosfet vary with changes in
Series Ferrite Cores ETD and the power table
ETD29 100 Number of turns of the primary winding W 2×6
ETD34 200 Number of turns of the primary winding W 2×5
ETD39 300 Number of turns of the primary winding W 2×4
ETD44 400 Number of turns of the primary winding W 2×3
Mosfet power table
BUK455-60A 100 Watt
BUK456-60A 200 Watt
STP50N06 200 Watt
STP60N06 300 Watt
STP80N06 400 Watt
IRF1010E 400 Watt
IRFZ44E 300 Watt
BUZ11 100 Watt
BUZ12 200 Watt
the control circuit to be flexible in terms of the integration of the best reasons for the choice not know the power TL494 (dbl494, ka7500) Although it is very cheap and it's easy resources produced nor sold reliable short-circuit protection circuit is also part of my work with integrating the different ideas that gave ;)
Sprint Layout PCB source circuit diagrams and explanations which I prepared with pdf files: TL494-by-2×32-volt-oto-amplifikator-glycine-SMPS-besleme-devresi.rar
Load tests after the LM3886 or TDA7294 amplifier circuit to a nice stereo with…
Amplifier, amphi, car, car smps, dcdc, ferrite core, mosfet, car SMPS, TL494, transformer,
320volt yazarları
Author: Burhan
Published on 07.09.2008 2x32 Volt Supply with TL494 SMPS for Car Amplifier total post 90
Random Post
PC RS232 8 Kanal Röle Kontrol PIC16F628 RF TDA7294 300watt stereo amplifier circuit bridge bağlantı
Electronic Projects | 320volt.com Turkey in Turkey dealing with the development of IT and electronics to provide nice service to our people has been established to contribute to the development. | Infrastructure WordPress | simple electronic circuits | circuits archive
