320volt / Lm317 Current Calculator
Output Current mA
R* Calculated Resistor Value Ohm - Resistor Watt W
NOTE: This LM317 Current Calculator tool "LM337", "LM338 (5amp) ", "LM350 (3amp)" is compatible with supports
lm317-current-calculator-schematic
LM317 LM337 Regulator Connections
LM317T datasheet TO220 Case 1 amp power gives 1.5 amps when the file can give the necessary conditions are met, but said it would not be hard to implement these requirements max. one should think of it as power amps. LM317 TO-3 metal sheath can give 1.5 amps only problem with cooler mounting difficulties
lm317t-lm337t-pin
lm317k-lm337k-pin
Positive Regulator LM350 3amp LM338 5amp connections
lm338-lm350-2
Datasheets: LM117-LM317T-LM317K-DATASHEETLM137-LM337T-LM337K-DATASHEETLM150-LM350T-LM350K-DATASHEETLM118-LM338T-LM338K-DATASHEET
