Position:Electronics Blog Free Electronics Software Adjustable positive regulator calculator program
Program the LM317 adjustable voltage regulator positive (1 barely), LM350 (3 barely) ,LM338 (5 barely) doing calculations with the prefix application within integrated circuit diagrams.
Adjustable positive regulator calculator program: Adjustable-positive-regulator-account-programi.ZIP Thanks to those who contributed to preparing
Regulator calculation program usage information
RcALTIN / Recep GOLD hasangurlek / Hasan GÜRLEK (Temperature calculation formulas)
–> If the desired result out the exact calculation of the values ​​of R1 and R2 should be.
–> Output voltage fractional calculations to be made on the value of R2, rounded to the nearest whole number. For example: 719.6 O = 720 AZ
–> Output voltage fine-tuning R2 't recommend that you remove the option to calculate the automatic calculation for convenience…
–> Temperature θJA and θJC value calculation vary according to the component to be used;
θJA / θJC = Komponent – Sheath
39 / 2 = LM317 – K (TO-3)
50 / 4 = LM317 – T (TO-220)
50 / 4 = LM317 – S (TO-263)
140/ 23,5 = LM317 – EMP (SOT-223)
186/ 21 = LM317 – H (TO-39)
103/ 12 = LM317 – MDT (TO-252)
35 / 1 = LM338 – K (TO-3)
50 / 4 = LM338 – T (TO-220)
35 / 1,2 = LM350 – K (TO-3)
50 / 3 = LM350 – T (TO-220)
–> Right click on the tolerance values ​​of resistors can change the color codes shown in, The maximum output voltage + and – observe the voltage difference…
–> Decimal spellings “,”(comma) used. “.”(point) only be used as a separator line, has no effect on the values.
This program is completely free to use and free to be copied and distributed, can not be sold for a fee.
current regulator, LM315 account, LM338 account, calculation of the regulator, voltage regulator,
320volt yazarları
Author: gevv
Published on 19.06.2010 Adjustable positive regulator calculator program total post 1780
Random Post
STK4048XI 150W STK412-170 2X180W Amplifikatör Devreleri Smd komponent bilgileri (smd katalog programı)
Electronic Projects | 320volt.com Turkey in Turkey dealing with the development of IT and electronics to provide nice service to our people has been established to contribute to the development. | Infrastructure WordPress | simple electronic circuits | circuits archive
