CD4094B 6N135 İzole Unipolar Step Motor Sürücü
6n135-irf540-cd4094b-lm317hv-izole-step-motor-surucu
Bilgisayarın paralel portunu kullanarak step motor kontrol edilmesini sağlayan bir devre data girişleri 6N135 opto kublor üzerinden yapılmış bu sayede paralel lpt port korunmuş oluyor iki adet motor kontrol edilebilir kanal başına 5 amper güç verebiliyor toplam 10 amper gücü var sürücü mosfetler ise 8 adet IRF540 kontrol entegresi CD4094B
This circuit allows you to control through the parallel port eight power switches capable themselves of handling the various amps with voltages up to 50V. The circuit is, for security reasons, optically isolated from the PC
izole-drivers-stepper-motors-unipolar-schematic
The circuit is designed to drive loads that require a continuous supply voltage of between 14 and 50V (with some trick you can also use lower voltage power supplies), with a maximum current of 5A per channel (even if the tracks are printed circuit sized for 10A continuous total). I advise you not to use power supply stabilized: just a simple transformer, a diode bridge and an electrolytic capacitor of capacity (a thousand uF per ampere) or a set of 12 or 24V. Remember that the absorption of current and the voltage is high enough and therefore need a minimum of care when handling the circuit. In particular unrelated or disconnect the circuit at the power source in the presence of tension, sparking intense pain and a little “hygiene” for electronic devices.
drivers-for-stepper-motors-unipolar
Kaynak: Drivers for stepper motors unipolar alternatif link: cd4094b-6n135-izole-unipolar-step-motor-surucu.rar
  1. xXxTopRaK says:
    gevv eline sağlık paylaşım gayet güzel buna benzer AC motor sürücülerinin şemalarınıda ele geçirip paylaşabilsek gayet güzel olacak teşekkürler…
