Bob Stein`in Hazırladığı indiktör ve filtre Hepaplama Programı
Not:Programı Kullanmak için micro2003b.exe dosyasını çalıştırın
INDUCTANCE CALCULATOR
Ver 3.0
7-9-92
This program will calculate the following for round copper wire or copper strap:
1 - Inductance of a single-layer coil
2 - Turns in a single-layer coil for a specified inductance
3 - Turns from coil stock of known pitch (turns per inch or turns per cm)
4 - Inductance of a straight strap
5 - Length of a straight strap for a specified inductance
6 - Inductance of a transmission-line section
7 - Length of transmission line for a specified inductance
8 - Inductance of a wire parallel to and grounded to a ground plane
9 - Length of wire parallel to ground plane for a specified inductance
10 - Inductance of a straight wire
11 - Length of a straight wire for a specified inductance
12 - Inductance of a multi-layer rectangular coil
13 - Inductance of a multi-layer circular coil
14 - Turns in a multi-layer bobbin-wound coil for a specified inductance
The source code, written in GW-Basic, and the compiled program are not copy-
righted and are released into the public domain. No claims are made for its
accuracy or suitability for any purpose.
Bob Stein
inductance calculator
